Steering Wheel Squeal/Squeak Low Speed Turns
Results 1 to 8 of 8
Cadillac STS Forum - 2005 through 2012 Discussion, Steering Wheel Squeal/Squeak Low Speed Turns in Past Cadillac Vehicle Discussion; Hey guys, I have a concern on my 2005 Cadillac STS whenever I make a turn at low speeds my ...
    ambitionist is offline Cadillac Owners Member
    Dec 2012
    37
    Hey guys, I have a concern on my 2005 Cadillac STS whenever I make a turn at low speeds my steering wheel squeaks or squeals and I hear something from the inside assembly right behind the steering wheel but I don't know if it's a easy fix but if it is it possible to open the but inside and spray or grease something..? Another factor is weather conditions because when it was cold, it didn't make that noise but now that it's warm it makes it here n there... Thanks alot for any help!
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Steering Wheel Squeal/Squeak Low Speed Turns
    If it's the known issue, grease can help. I forget the specifics of the TSB but check the 'sticky' thread at the top of the forum.
    Dec 2012
    37
    Can't seem to find no sticky about that... Annoying noise -___-
    Dec 2012
    37
    Any 1...
    targetSTS is offline Cadillac Owners Fanatic
    Automobile(s): 2005 cadillac STS AWD 1SG
    Mar 2011
    33
    391
    check steering fluid level and overall condition.
    dirty fluid can cause this noise.
    Also it's can be bad steering pump. But first check fluid and replace if needed.
    Dec 2012
    37
    Checked the fluid, seems fine, it does it in different weather conditions, especially when it gets warm at low low speeds or being still you can hear it squeak.. Anyone else have an issue like this? I wanna open up behind the steering wheel and lubricate whatever I can see lol it's annoying!
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    A little lube might do it but early models did have some issues with the rack.
    Greg00coupe is offline Cadillac Owners Enthusiast
    Automobile(s): 05 STS
    Jan 2005
    Canton, Oh
    64
    512
    Have this same issue, comes and goes. Dealer lubed it back in 08, seems to be more prevelant in warm weather, never in the winter. Something I can tolerate but lubing it did help.
  11. Remove Advertisements
