Something doesn't feel right, and the back end has been sliding out some on turns with what I believe is mild to moderate acceleration, especially on turns. The tires appear to have quite a bit left in them, so I don't think that is the problem.
I'm looking to get them aligned/rotated/balanced. Initially I called the dealer but they weren't accommodating to my schedule and said they only had one loaner that was already out, so I'd like to give someone else my business.
What are your thoughts on Sears, Walmart, Sam's and mom and pop shops for this job? Is the dealer worth it, or can I feel comfortable having one of these other stores do it and as far as chains go, which one is the best?
Balance issues would be vibrations
It might need an alignment...
However; my thoughts on that are basically would you take a corvette to a chain for an alignment?
You want to get a road force alignment done somewhere that has a good reputation.
These cars tend to hold an alignment very well. Unless you feel it pulling to one side or have uneven tire wear, I wouldn't spend the money.
Any decent shop with a Hunter can do a good job balancing your tires; but how old are they? If they are over 5-years old, start looking for new tires. If they are still the OEM Michelins, you'll find anything else an improvement.
Just checked the tires and they are Michelin Pilot Sport A/S Plus, made in April of 2010. There is plenty of tread left. Tires are all somewhere around 30psi.
I'm not noticing any vibrations or pull, but the tires don't seem to be hugging the pavement very well.
Most people on here say conti dws. I have General GMAX AS03. They do just fine in my mind. Nice aquatread pattern good traction for all seasons.
I have AWD though too. You can use rear size on all wheels with no issues.
I think the Michelin's are too hard in hopes of long wear. This hurts handling and increases noise. Conti's are a lot softer compound but there are many choices. Tires amount to the biggest single way to make your car better suit your preferences.
You can also use the 235/50R18's all the way around if you prefer a quieter, more compliant ride.
Parents did the rear size on all 4 for the SRX that needed tires. I think it's handling is better / a bit more aggressive. They have the same wheelbase so I would expect a similar change. Also picking one size allows for rotation and more tire choices as not all tires are available in both sizes to accommodate the staggered setup.
I just bought 4 new michelins oem for my car because I am very pleased withe the tread wear
The fact that they are the originals (5yrs old)(37000 miles) still enough tread for 5k more. I went with the same set. Staggered front and rear,
Very nice ride. That's my personal opinion.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
