Can't open driver side door except with key.
Results 1 to 10 of 10
Cadillac STS Forum - 2005 through 2012 Discussion, Can't open driver side door except with key. in Past Cadillac Vehicle Discussion; I have a 2005 sts and just yesterday this started. If I click the unlock button on the chirper it ...
    IceDigger's Avatar
    IceDigger is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS Northstar
    Nov 2004
    Bucks County, PA
    37
    147
    I have a 2005 sts and just yesterday this started. If I click the unlock button on the chirper it unlocks all the doors but the drivers door. The only way to unlock it is if I use the key or unlock it from the inside. Any ideas?
    dannyquest is offline Cadillac Owners Fanatic
    Mar 2012
    columbus ohio
    382
    Re: Can't open driver side door except with key.
    IceDigger, Common problem with the door. Same thing happen to my 06 STS. I replaced the driver micro switch. Located inside the door. Most dealers will want to replace every thing in the door. That how they stay afloat. Call rippy's auto parts. Danny
    IceDigger's Avatar
    Nov 2004
    Bucks County, PA
    37
    147
    Thanks for the heads up. I'll get my brother in law to fix it. While he is at it, gives me an excuse to dump the stock non nav unit and put in an alpine head unit
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    You'll need the OEM radio to change the memory seat, remote start, & security settings. Some members wire it into the system from the trunk. I think there are also some aftermarket solutions. Do your research.
    LiquidTrader is offline Cadillac Owners Fanatic
    Dec 2011
    152
    Same thing on my passenger side door. If you pull it slowly and just right then you can get it.
    How much is the micro switch?
    Mar 2012
    columbus ohio
    382
    LiquidTrader, $85. & includes shipping at Rippys auto parts. Danny
    silver02ta is offline Cadillac Owners Member
    Automobile(s): 2005 STS V8
    Nov 2011
    35
    47
    Is there a link...I searched rippys auto parts and there are afew..
    davidmb377 is offline Cadillac Owners Member
    Automobile(s): STS
    Mar 2013
    1
    19120306 is the part # for the drivers door it's called the k housing. Also for a temporary fix until your new k housing gets replaced you can spray electrical contact cleaner through the door handle with an aerosol can with a straw attached to it the contacts that get corroded are on inside the handle. Pull out on the handle and spray downward. I used brake cleaner (not the best idea but it was just temporary until my new k housing came in)
    Mar 2012
    columbus ohio
    382
    silver02ta, 1-800-rippy22 ask for chriss. Also I just used the mirco switchs out of the assembly because it was much easier. Danny
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Be very careful with solvents. I always test them on a hidden spot to keep the finish safe. Most contct cleaner should be fine.
  13. Remove Advertisements
