Are 22's to big - Page 2
Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 66
Like Tree10Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Are 22's to big in Past Cadillac Vehicle Discussion; What does Stabilitrak do if the front and rear tires have significantly different circumferences? Will it think there's wheel slippage ...
  1. #16
    ral1960 is offline Cadillac Owners Fanatic
    Automobile(s): 2008 DTS Perf-Plat, fr 11 STS, 04 DeV, 76 Eldo Con, 74 Fltwd
    Jan 2005
    NC
    436
    Re: Are 22's to big
    What does Stabilitrak do if the front and rear tires have significantly different circumferences? Will it think there's wheel slippage and apply the brakes?
    The stock tires on my car are slightly different in diameter already. I assume the speedometer/odometer run off the rear wheels, so if I went to a 235/55 instead of 50 in the front only, I'd gain almost half an inch of sidewall. In the Continental DWS, it's also $25/tire cheaper than the 235/50. The revs/mile would be 716 and 746 instead of the stock 740 & 746.
  2. #17
    Four Fins's Avatar
    Four Fins is offline Cadillac Owners Member
    Automobile(s): 61 Sedan, 06 STS
    Jul 2012
    35
    40
    Re: Are 22's to big
    Here's mine with 20's. Only a 1/4" different than stock 17" size. No rubbing at all and plenty of fender gap (a little more than what I want) but I had 22's and if I hit a big enough dip with people in the back it would rub, only because of the rim offset. If you get something that tucks I wouldnt see a problem, but then again I didn't care for the ride of 30 series tires.542135_519483824750347_197547225_n_zps1a0c8ca8.jpg
  3. #18
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Are 22's to big
    Sandwich - There are a few non-V's with the six-lug wheels & V brakes.
    I'm not sure the 17" wheels will clear the mid-option brake calipers.
  5. #19
    eatyoursandwich is offline Cadillac Owners Fanatic
    Automobile(s): 2007 STS N*
    Jan 2012
    Austin, TX
    31
    265
    Re: Are 22's to big
    Quote Originally Posted by EChas3 View Post
    Good call. I forgot about that.
  6. #20
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,496
    Re: Are 22's to big
    @eat - I think the user 1SG_LAC (or something like that) has a nice Red STS with the V brakes.
    What on earth happened to cause that 4 lugger to break like that?
  7. #21
    Platinum06's Avatar
    Platinum06 is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 N* STS-4
    May 2006
    Chicago
    530
    Re: Are 22's to big
  8. #22
    dkozloski's Avatar
    dkozloski is online now Cadillac Owners 10000+ Posts
    Jul 2004
    Fairbanks, Ak
    28,213
    Re: Are 22's to big
    20s look best on a Kenworth.
    Don't mess with Binky Bear!
  9. #23
    deerozay2105 is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac Sts
    Feb 2013
    1
    Re: Are 22's to big
    No i had 22 u2 wheels fit perfect didnt have to get lifted little rub but after it rubs down the liner it wont b an issue as far as speed there is a 5 mph difference.
  10. #24
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,033
    I have JE5 brakes on my 1SF, not sure if that's the mid-option, but the 17" wheels from my old CTS clear the calipers. I use them for my winter wheels.
  11. #25
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Are 22's to big
    Base is JL9 - my wife's 1SE has them. They are OK.
    Nice to hear that 17" wheels clear the JE5 calipers. I don't think Cadillac pairs them together. I was referring to these as mid-option. The V brakes are bigger yet.
  12. #26
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,033
    They barely clear, probably less than 1/4", I was worried about that very thing prior to having them mounted.
    So far so good though.
  13. #27
    orange57's Avatar
    orange57 is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 STS Northstar RWD
    Nov 2010
    Phoenix, AZ
    34
    511
    Re: Are 22's to big
    Personally, I think 22's would be too big. Four Fins, those 20's look pretty good. I have the stock 17's. I wouldn't mind going up to 18's or 19's. But currently i'm happy with the 17's. Actually, I would really like to get a second set, and then get them sand blasted and powdercoated something not shiny chrome.
  14. #28
    ddalder's Avatar
    ddalder is online now Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,800
    Re: Are 22's to big
    Personally, I think the ride is rough enough with 18's. Wouldn't even think about 22's, not to mention I think it looks horribly disproportionate. If you're looking to stand out, those will do it, but I'm not sure it is in a positive light. To each their own though.
  15. #29
    Jan 2005
    NC
    436
    Re: Are 22's to big
    If you want to stand out, it's much cheaper to paint flames coming out of your wheelwells. I did that on my 74 Fleetwood--for a friend's wedding.
  16. #30
    orange57's Avatar
    Nov 2010
    Phoenix, AZ
    34
    511
    Re: Are 22's to big
    Quote Originally Posted by ral1960 View Post
    That is why I want stock non-chrome wheels, so they stand out less. I would like to do a gunmetal grey color, or something similar.
  17. Remove Advertisements
