Project HUD - Page 8
Page 8 of 11 FirstFirst 1234567891011 LastLast
Results 106 to 120 of 162
Like Tree15Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Project HUD in Past Cadillac Vehicle Discussion; I haven't tried this. There are a couple of settings when configuring the vehicle options. One of the first screens ...
  1. #106
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,870
    Re: Project HUD
    I haven't tried this. There are a couple of settings when configuring the vehicle options. One of the first screens allows for the selection of the country (the list is actually quite lengthy). I know that in some countries DRL's are not active. It may require changing the country selection to do this though. I have no idea how this would change other vehicle parameters. The export alarm is different as well as several other parameters (ie, no VCIM). When I have a chance I'll try changing the DRL setting without changing the country and see what happens. My vehicle was originally manufactured for the US market but I noticed that when it was imported, the dealership changed this setting to Canada.
  2. #107
    PontiacV8's Avatar
    PontiacV8 is offline Cadillac Owners Fanatic
    Automobile(s): 2015 Camaro 2SS, Sold: 2006 STS (EXP) 1997 Seville STS (EXP)
    Dec 2006
    Germany / Nordhorn
    424
    Re: Project HUD
    Quote Originally Posted by 1BadCadSTS View Post
    Daddler does shutting off DRL in the IPM turn off the amber turn signals during the day?
    Quote Originally Posted by ddalder View Post
    II know that in some countries DRL's are not active. It may require changing the country selection to do this though.
    ...should work...you know, "amber" colored DRL isn't allowed in european ECE area countries...so it is disabled on export cars...
    ...remember my question in this thread (about activating DRL on my export STS) ?
    http://www.cadillacforums.com/forums...ml#post3389825
    http://www.cadillacforums.com/forums...ml#post3398297
    ...after asking my dealer he has done it for me on my car via Tech 2 (...just for testing) ...don't ask for details ...but it was done very quickly...and has worked...
    ...so disabling should...or could also work...vice versa...
  3. #108
    ddalder's Avatar
    Aug 2008
    Canada
    2,870
    Re: Project HUD
    I figured that this is possible, I'm just not sure if it requires changing the country ID or just the DRL parameter. Both are easily and quickly accomplished with just a Tech2. I've never tested it because I personally believe DRL's are a good idea and have no interest in disabling them.
  5. #109
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    I'm tired of burned out turn signal bulbs as well as everyone for the most part here knows my hatred of amber lights on cars haha.
  6. #110
    ddalder's Avatar
    Aug 2008
    Canada
    2,870
    Re: Project HUD
    It's odd that you are having problems with bulbs burning out. I've had my STS for 3 years now and never had a DRL/signal bulb burn out. I've only ever had to replace one side marker bulb.
  7. #111
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Srx has a tsb for melting sockets. If you don't mind testing it ill tell my dealer to shut it off when they turn on HUD.
  8. #112
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Daddler
    Can you list the steps you took to access the ipm to manually change options.
    My dealer says they cannot make changes on it I was going to provide them instructions how to get to the menu like you have.
    They said unable to communicate with module when they tried. It may be they meant the ipm could not detect the HUD so it wouldn't turn on I'm not sure.
  9. #113
    ddalder's Avatar
    Aug 2008
    Canada
    2,870
    Re: Project HUD
    As soon as I have an opportunity, I'll either list the steps or make a video. My question is the same... were they unable to communicate with the IPM, or did they successfully connect to the IPM but when they tried to turn it on they got an error? If they were unable to connect to the IPM, the vehicle would use the backup settings stored in the RIM, but there should be a DTC set for 'Lost Communication With The Instrument Panel Module'. The only time I've ever had an error that the Tech2 was unable to connect to a module was when the module was defective (or missing), or the vehicle was built incorrectly in the Tech2 (wrong vehicle selected).
  10. #114
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Re: Project HUD
    I only spoke briefly with the tech when I stopped in to pick up my ARP bolts and gaskets to finish my LS2 build on the Camaro (were in the trunk and has been for several weeks so figured about to time to drop by and grab those) and the techs words were that he tried to turn it on but it was unable to communicate. I didnt think to ask if he meant the IPM or since the HUD isnt present yet it wouldn't turn on.
    I HIGHLY doubt there's an issue with my IPM. I monitor the module with my Snap on Ethos (incapable of bilateral controls but can read all modules) and I never had a failed IPM code.
    I look forward to your video, I GREATLY appreciate it.
  11. #115
    ddalder's Avatar
    Aug 2008
    Canada
    2,870
    Re: Project HUD
    Haven't forgotten about the video, just been very busy. I finally set-up my a new stand and TV for my sister tonight. She's been waiting about 5 weeks. It won't be that long, probably in the next 5-6 days.
  12. #116
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Thanks daddler as always!!!
  13. #117
    ddalder's Avatar
    Aug 2008
    Canada
    2,870
    Re: Project HUD
    I tried to send you a PM but you are at your maximum limit...
  14. #118
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Cleared. Sorry!!!
  15. #119
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Re: Project HUD
    Darcy, do you know the name or a part number for the threaded inserts that mount into the dash carrier that bolts the HUD down? Thanks!
    EDIT
    Got it
    25536302
    3 needed.
  16. #120
    ddalder's Avatar
    Aug 2008
    Canada
    2,870
    Re: Project HUD
    EDIT
    Got it
    25536302
    3 needed.
    That's pretty much what I was going to post. They are a metal clip that expands slightly as the screw passes through preventing them from pulling out. It is the same part that's used in other parts of the dash. Very common at the auto wrecker in a lot of GM vehicles. I have about 30 of them sitting on the shelf.
  17. Remove Advertisements
