Project HUD - Page 7
Page 7 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 91 to 105 of 162
Like Tree15Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Project HUD in Past Cadillac Vehicle Discussion; Yes, everything as you see it is intact with the exception of the defrost trim panel that snaps into place ...
  1. #91
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,812
    Re: Project HUD
    Yes, everything as you see it is intact with the exception of the defrost trim panel that snaps into place on the top of the carrier. There isn't a metal plate in there. Which picture are you referring to? The white insulation comes up through the cutout but actually covers the left hand side of the plastic HUD housing. If that insulation wasn't there, all you'd see is the remainder of the HUD assembly visible through the cutout.
  2. #92
    NoKSuCoW is offline Cadillac Owners Member
    Automobile(s): 2011 STS
    May 2013
    32
    11
    Re: Project HUD
    Does this have anything to do with a rear camera? C360_2013-05-10-15-21-27-861.jpg
  3. #93
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    These cars NEVER had a back up camera. No way to add one to a factory system. Period.
  5. #94
    May 2013
    32
    11
    Re: Project HUD
    So what your really trying to say is?? Just kidding...lol
    Okay so the only way is a new screen + camera or cts cam + mirror and lose intellibeam?
  6. #95
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Quote Originally Posted by NoKSuCoW
    Correct
    The export SLS has a camera you can use or aliexpress sells SLS add on cameras which will work but you'll need a display.
  7. #96
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,524
    Re: Project HUD
    Here are some close ups I took of the window, not sure if they will be useful or not but I figured they couldn't hurt.
    All are very large resolution so you may want to open them in a new tab to get full size.
  8. #97
    ddalder's Avatar
    Aug 2008
    Canada
    2,812
    Re: Project HUD
    Quote Originally Posted by NoKSuCoW View Post
    Does this have anything to do with a rear camera? Attachment 112081
    This is a diagnostic connector for the Ultrasonic Rear Park Assist system.
  9. #98
    Maximln is offline Cadillac Owners Enthusiast
    Automobile(s): 08 STS V8 AWD, 1SG, Platinum Edition
    Jan 2003
    Fresno, CA
    666
    Re: Project HUD
    Hope your HUD project is working good! I love to see how people can adapt different accessories to their car. My first Cadillac was a 75 Sedan de Ville d' Elegance that is still probably my favorite Cadillac. It came with the Twilight Sentinel option but not the Auto High Beam dimming option. I got all the parts for the Auto Dimming option at a wrecking yard & installed them into my car & it worked perfectly! Something so fulfilling about it!
    If you do get your HUD to work, you will most likely have to replace your windshield. I had to replace the windshield on my car a few years ago & I told the insurance co. they had to replace it with a factory windshield because of Rainsense & the HUD. Sure enough, they did not listen to me & when I got my car back, Rainsense did not work properly & my HUD reflection was blurry as heck! They allowed me to order my own windshield from GM & there were 2 available. One with HUD & one without HUD. I'm guessing the one with HUD is "more polished" in the area where the HUD is reflected. Hopefully yours will be different!
    Max
  10. #99
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Project HUD
    I think it's actually got polarization to improve the HUD.
  11. #100
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    AFAIK, any type of projection on glass requires a polarized area.
  12. #101
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Project HUD
    As noted early in the thread and in the many HUD upgrades on various places on the web, most automotive glass will work but better results involve additional measures; the best results can get expensive. Nothing new there.
  13. #102
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    So just a little update
    Found a donor car at local yard and have started to assemble everything. 1st up my conversion harness.
    I was happy to find the HUD only uses 7 wires. 4 come from the info control switch the other 3 are ground and gm LAN low speed which both come from SP201 and last is a 12v power source which is supposed to come from the front fuse box but I will be tapping into the rear to avoid running wire in the engine bay.
    As the picture shows I already have the proper info switch plug (not the same as non hud cars) and the HUD projector plug wired together.
    Next step will be getting some terminal leads to connect into the factory SP201 on the passenger side left part of the dash and then to the fuse box so in theory there should be no cutting or splicing into the factory wiring.
    The most difficult part will obviously be removing the dash carrier, cutting it out for the HUD display and hoping everything works and displays properly through the HUD without any needed programming to the other modules.
  14. #103
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,524
    I would think you would have to enable the HUD via a tech 2 otherwise I would bet the car isn't going to broadcast the info it is going to pick up from the LAN bus.
  15. #104
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Quote Originally Posted by Ludacrisvp
    I thought the same thing. However daddler shut off the RPO in his system and it still provided full data to the HUD.
    Quote Originally Posted by ddalder
    Interestingly, after changing the settings in the IPM/RIM, there was no change in the operation of the HUD. I can tell you that the car will set a DTC for an incorrect number of modules detected on the data bus if options are not set correctly. I'm not certain exactly what other functions the configuration information controls, in light of this new information.
    See above
  16. #105
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Daddler does shutting off DRL in the IPM turn off the amber turn signals during the day?
  17. Remove Advertisements
