Shock replacement. OEM vs Aftermarket?
Results 1 to 13 of 13
Cadillac STS Forum - 2005 through 2012 Discussion, Shock replacement. OEM vs Aftermarket? in Past Cadillac Vehicle Discussion; My rear shocks are shot so i need to get new ones. I found a hole in one of the ...
    shortfur7's Avatar
    shortfur7 is offline Cadillac Owners Fanatic
    Automobile(s): 2014 ATS4 2.0
    Jul 2011
    31
    143
    My rear shocks are shot so i need to get new ones. I found a hole in one of the shocks which in turn now my compressor is shot and when putting air through the lines i found some holes in the lines also. So my question being is to replace all 3 components its going to be over $2000. That being said its hard to justify that when resale value of the car in perfect condition in my area is only $6000.
    So in turn im looking at getting one of the following for replacement and wondered if any of you have experience with them.
    http://www.suncoreindustries.com/cad...ersion-kit.php
    Thanks in advance
    I guess not quite $2000 GMpartsdirect has the following prices for me.
    Left- $490
    Right- $460
    Comp- $365
    Tubing- $70
    So still $1385 vs $600 or $700 for the aftermarket ones.
    stevenriz is offline Cadillac Owners Fanatic
    Automobile(s): 2008 STS4 V8 1SG Platinum Edition
    Apr 2009
    Central MA
    49
    465
    Re: Shock replacement. OEM vs Aftermarket?
    What ever happened with you here? I am in the same predicament Need shocks, leaking all over the place... Can't justify the 1000s to fix...
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,171
    It's now a $6000 car but you have to buy parts for a $60,000 car. The cheap turns out to be expensive.
    Don't mess with Binky Bear!
  5. #4
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,028
    I was unaware that there are aftermarket shocks for MRC equipped cars available. If so, how would you fool the system into thinking the system is still intact? I know with the older F45 CVRSS system you just had to install a resistor to complete the circuit.
  6. #5
    Apr 2009
    Central MA
    49
    465
    The kits listed above have instructions on disabling the air system from what I can tell..
  7. #6
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,028
    Quote Originally Posted by stevenriz View Post
    I'm not referring to self leveling, which is where the air compressor comes into play. I am referring to the active electronic suspension, I see it says there's instructions on disabling it, just wondering how it does it.
  8. #7
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,478
    I cannot imagine that it is going to properly disable a F55 equipped car's suspension system.
    "This kit will convert the Front [or rear] of your STS from Active Electronic Gas Shocks to Passive Gas Shocks."
    The MRC shocks aren't what I would call to be "Gas" Shocks.... the label on the shock itself (at least for the bad rear one i have laying in the garage) says that it contains Oil and Gas under pressure.
    Part of me would believe that the 'gas' part would be the warning for the air-ride portion of the shock and the oil part is the active MRC portion.
    Get OEM from Rippy and do it right. You could likely have a new pair of rears installed for $900 and they would be OEM new with warranty and give you the ride you should have.
    If the compressor is shot well that is another story, not sure how you have confirmed this is bad and at $400 plus labor I would want to confirm it.
    The fronts would run a bit more, probably $1000 for the pair and then the labor to install those and do an alignment. (rear only does not need alignment done).
    So call it $1800 for 4 new MRC shocks from GM w/ warranty intact, plus a couple hundred to install and align.
    Those aftermarket ones are $1200 for all 4 plus an unknown amount for shipping.
    I added them to the cart to see if they would show shipping costs and they were suddenly no longer STS shocks, they are SRX shocks.
    So they were made with the SRX in mind that was very rare to have the MRC setup on it.
    Additionally you would then be highly likely to have your speed limited to 80MPH (as my testing has shown you get if you have certain parts of your suspension disconnected) and believe me it really does limit it to 80.
  9. #8
    Apr 2009
    Central MA
    49
    465
    Thanks, great info... Are these difficult for an amateur to install? What is the procedure? Jack it up enough to drop the wheels just enough to take pressure off the shock itself and then R&R... ? Does anyone know torque specifications? I will ask a friend that works at the local Ford dealer and hope he is able to assist...
  10. #9
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    I can bypass magride. Done 1 DTS and 2 lades.
  11. #10
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,028
    Quote Originally Posted by 1BadCadSTS View Post
    Enlighten us please.
  12. #11
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Resistor trick just like with old cvrss. Need wire wound resistors though 2 1ohm resistors per strut. Made a post about it before. While I enjoy magride and would never defeat it on my own personal car others don't like to pay to play.
  13. #12
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    There are aftermarket substitutes for MRC shocks that are all some extended warranty companies will cover. I read about them here from a member. I'm tempted but will probably buy from Chris at Rippy's if and when.
    This debate about repair cost exceeding the value of ones car is looking at the wrong number. I think replacement cost is far more important than some speculation about market value IF in good condition. What do you care? No one is going to offer you that for a car that needs an expensive repair, anyway. If it isn't repaired, nobody will buy it. A dealer might take it in trade, but only by inflating the purchase price (or terms) of the car you buy.
    Looking at a repair this way can prove enlightening. Should I spend $2,500 (or let's include tires & brakes and make it $5,000) on a car that I know or unload it (broken) for next to nothing and spend HOW MUCH? on its replacement?
    Get real. Sure, there comes a time to unload a car, but focus on real out of pocket costs, not some fiction that you'll never see, anyway.
  14. #13
    turnne is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac STS
    Oct 2007
    Indianapolis Indiana
    52
    1,209
    Quote Originally Posted by EChas3 View Post
    Echase
    this is what I call financial reality...and what 90% of automobile owners are going to live by
    I agree with you that not repaired, the car is practically worthless....so its a catch 22
    However...90% of the people are not going to fix a car where the repair cost/car value ratio is where it is in this situation
    Would you have considered fixing your HG if your old car had been worth 2x-3x of what it was?
    And the cycle continues with older Cadillacs and the value retention. Either someone buys it cheap used and cant afford the repairs...or someone is unwilling to pour money into a car that is relatively low in value......Enter "Buy Here pay here" car lots next to the Jaguars that have the same value retention issues and expensive repairs
    I for one dont think these MRC shocks add much in the way of overall ride and handling..vs cars with passive systems that rode and handled better
    One caveat with the older cars is/was the ability to bypass this system and use passive shocks
    This added new life to many of the older STS body style cars. I dont think you will have many that will drop $2500 in a 6K car...most will probably just keep driving it and let the chips fall where they may
    how many 6-7 year old Caddy's have you seen driving around with warning lights on..."Check Ride Control" being one of them?
    Warren
  15. Remove Advertisements
