Same size tires all around - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Like Tree5Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Same size tires all around in Past Cadillac Vehicle Discussion; I've got over 25,000 on mine and they are still quiet and have great traction. I do rotate them every ...
  1. #16
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Same size tires all around
    I've got over 25,000 on mine and they are still quiet and have great traction. I do rotate them every oil change, roughly annual & 10k.
  2. #17
    jsiddall is offline Cadillac Owners Fanatic
    Automobile(s): 09 SRX V8 AWD Sport, 06 STS V8
    Oct 2009
    Ottawa, Canada
    43
    159
    I just put winter tires on my STS, same size Dunlop SP Winter Sport 3D 235/50R18 all around with aftermarket Niche NR10 rims. So far so good.
  3. #18
    06 STS Rob's Avatar
    06 STS Rob is offline Cadillac Owners Fanatic
    Automobile(s): 08 STS V, had 06 V6 STS
    Jul 2010
    Lake Elsinore,CA
    40
    427
    I ran 255/35/20's on all 4's for about 10k miles with no problems at all. They were Nitto 555's on KMC Dimes. I enjoyed them right up to the day I traded the car in. The Nitto's were good for So Cal but the guys on the east coast who actually have winter months may not like them. Car was a little rough compared to stock, but by no means did it ride rough. I got many compliments from people that rode in the car about how smooth it was with 20's.
  5. #19
    kschwed is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Cadillac STS 1SC
    Nov 2009
    California
    28
    383
    I got the DWS's put on a couple days ago and couldn't be happier. I went the same size all around.
    Thanks for the tips guys.
  6. #20
    konoplya is offline Cadillac Owners Member
    Apr 2013
    6
    sorry fellas to bring this up from the dead, but the STS 4 that i have has the same size tires as OP (235R5017). i need some new tires and found a guy that has a whole set of almost brand new 225R5017 for a great price. i know the size is a little smaller but was wondering if that would work without problems on stock STS rims? thanks!
  7. #21
    C&C's Avatar
    C&C
    C&C is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac XT5 (2017)
    Feb 2008
    Mount Pleasant, SC
    66
    1,921
    They would work, they would fit the rim but the speedometer is going to read faster than you are really going. About 2% difference (using Michelin MXM4 specs).
  8. #22
    Apr 2013
    6
    Quote Originally Posted by C&C View Post
    not that i would particularly care about that, but whats the explanation behind that? 225 is the width so how would that impact the speedometer read? i was more curious whether the 225 would be too narrow and cause long term problems for the wider stock rim or vice versa. thanks!
  9. #23
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    225 (width) in mm
    50 (aspect ratio) percent value that the side wall is in comparison to the width
    17 (wheel size) in inches
    so the overall diameter of that tire in inches is (225)x(.50)x(2)x(.03937)+17 = 25.85825 inches
    the x2 is for the two sidewall sections and the .03937 is to convert the mm to inches
    for your factory 235/50r17 the overall diameter is 26.25195 inches
    some more math gives you the difference in circumferences which then leads you to the % difference the spedo will read off
    btw, there are online calculators to check if two tire sizes have the same overall diameter (or if they're close)
    note that the sts and srx vehicles that have these staggered tire sizes still have the same overall diameter for both the fronts and the rears (although that doesn't mean you can/should rotate them)
    and for the record, i only recommend using the factory tire sizes (on any vehicle)
    re: wider/narrower tires -- the contact patch with the road is not as large on a narrower tire so the traction will break sooner
    C&C likes this.
  10. #24
    1crock is offline Cadillac Owners Member
    Apr 2010
    71
    While that's the theoretical size of the tire, it's best to check the actual diameter. Tire rack and some other places have those numbers. Theactual size and the calculated size aren't always the same.
  11. #25
    Sep 2007
    Wilmington, NC
    13,986
    true
  12. #26
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    FWIW, the STS AWD uses open differentials, so you'd be fine, mechanically. If the used tires are over five years old, they are suspect, regardless of the tread.
  13. #27
    Apr 2013
    6
    ah ok. some really good information. thank you guys so much. the tires are from 2012 that my buddy has so i should be good. they're literally like new.
    i never really thought about the width from the mathematical perspective like that, i just thought about the 50 being 50mm and not a percentage figure. thanks for that.
  14. Remove Advertisements
