Manual Shift Transmission no longer works
Results 1 to 5 of 5
Like Tree1Likes
  • 2 Post By 1BadCadSTS
Cadillac STS Forum - 2005 through 2012 Discussion, Manual Shift Transmission no longer works in Past Cadillac Vehicle Discussion; My shift no longer works? Any ideas what would cause this? It will go into Sport drive, but I cannot ...
    heath71 is offline Cadillac Owners Member
    Automobile(s): 2005 sts4
    Oct 2012
    5
    My shift no longer works? Any ideas what would cause this? It will go into Sport drive, but I cannot manually shift up or down. Auto works fine.
    any help is appreciated.
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Shifter need replaced. Bad shifter. Told you this in other thread.
    Ludacrisvp and Ludacrisvp like this.
    Oct 2012
    5
    Re: Manual Shift Transmission no longer works
    There are many parts that comprise the shifter, I would assume it's a linkage of some sort...not the entire shifter...everything else works fine.
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    No seperately serviceable parts. It's the whole assembly which mounts in the center console.
    B1n2fra's Avatar
    B1n2fra is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 1SG STS v8 awd
    Nov 2011
    Chicago
    36
    502
    I also have the same issue and I was gonna buy a shifter but I wanted to know could I dismantle the shifter and fix the part thats malfunctioning instead if changing the entire shifter.because it's like a switch or something that initiates the sport mode and the manual shifting.. Any ideas??
  8. Remove Advertisements
