Side marker lights(front fender) - Page 8
Page 8 of 10 FirstFirst 12345678910 LastLast
Results 106 to 120 of 146
Like Tree10Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Side marker lights(front fender) in Past Cadillac Vehicle Discussion; So if we were to swap the dual filament bulb with a single filament one, everything would operate flawlessly?...
  1. #106
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Re: Side marker lights(front fender)
  2. #107
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,559
    Yeah it should as long as the single filament version had the metal contact in the same place as the high power filament does.
  3. #108
    Feb 2013
    Whitestone, NY
    28
    3,211
    I purchased the vauxhall fender repeaters. The black ones. And after a bunch of emails back and forth with Tracy at autolumination, I purchased a pair of 80 watt amber leds and 100 watt, 6 ohm load resistors.
    Tracy was very patient with me and happy to answer questions so that says something to their service. I was happy to make a purchase after dealing with the exemplary service. I'll keep you posted on how it ends up going.
    On another note, I've never installed load resistors so I guess I'll be hitting up youtube.
    More to follow.
  5. #109
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,559
    80 watt seems a bit excessive.... I think the standard lamps are only like 27 watts. How many lumens or candles is the output rated at?
  6. #110
    Feb 2013
    Whitestone, NY
    28
    3,211
    Don't know but I asked if I was possibly sacrificing longevity by going with the 80 versus say the 50 and the answer was a simple no.
    He also mentioned this:
    The 80 watt bulbs do not use 80 watts. That is the combined rated wattage
    of all the leds used in making that bulb. At 12 volts, they use closer to
    8 watts than 80.
    So that might answer that question.
    As far as light output, I'll find out.
  7. #111
    Feb 2013
    Whitestone, NY
    28
    3,211
    The 80 watt is 800 lumens and the 50 watt is 600 lumens.
    Knowing how bright 800 lumens is.. might that be too bright? I wonder what the output of the stock bulbs is. Anyway, I'm the guinea pig so I'll let you know how it goes.
  8. #112
    Feb 2013
    Whitestone, NY
    28
    3,211
    Quote Originally Posted by Ludacrisvp View Post
    They arrived today in the mail.
    I tried both polarity configurations and they seemed to work regardless of the way they were plugged in.
    Which does seem odd for LEDs...
    They arrived individually wrapped in a bubble wrap pouch, no protective film on them.
    There is a screw in the backing of it (didn't remove it) not sure if they would come apart or not but I would expect that the screw isn't there for decoration.
    While they do seal up nicely like the OEM lamps do they go too deep into the fender well area and you are unable to push them in all the way without breaking something.
    So I had to wrap them up with electrical tape to seal out the elements.
    Mine came in and I plan to work on this tomorrow. Can you clarify where you had issues and where you had to put electrical tape to solve it? I'm looking at those pictures and I don't see electrical tape. If pushing the light all the way into its seat in the fender is going to "cause something to break" what did you do to prevent it? Thanks
  9. #113
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,559
    Basically when you get to this point you'll have to wrap the wires in electrical tape or a heat shrink tube that is flexible to keep water out. And feed the wires back in like this so it can flex down so there is room for the longer shaft.
    If you go this far it looks all neat but when you push into the fender in this configuration is when it will not work and will break something.
    ^^^ as in this won't work to get It back in the fender.
  10. #114
    Feb 2013
    Whitestone, NY
    28
    3,211
    Ok got it. Thanks.
  11. #115
    targetSTS is offline Cadillac Owners Fanatic
    Automobile(s): 2005 cadillac STS AWD 1SG
    Mar 2011
    34
    410
    does it has resistor inside to prevent hyper flash?
  12. #116
    PontiacV8's Avatar
    PontiacV8 is offline Cadillac Owners Fanatic
    Automobile(s): 2015 Camaro 2SS, Sold: 2006 STS (EXP) 1997 Seville STS (EXP)
    Dec 2006
    Germany / Nordhorn
    424
    ...no aux./additional resistor needed, Alex....it's "plug and play"
  13. #117
    Mar 2011
    34
    410
    I know Heiner,
    Just wondering if I need resistor instead if I install this lights.)))
  14. #118
    PontiacV8's Avatar
    Dec 2006
    Germany / Nordhorn
    424
    ...these aftermarket led fender repeater turnsignals do have a kind of electronic or whatever inside to prevent hyper flash...
  15. #119
    Mar 2011
    34
    410
    OK. Will try. Thanks
  16. #120
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,559
    I don't have any hyperflash issues, if I did I wouldn't use them... Hyperflash really annoys me.
  17. Remove Advertisements
