Side marker lights(front fender) - Page 10
Page 10 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10
Results 136 to 146 of 146
Like Tree10Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Side marker lights(front fender) in Past Cadillac Vehicle Discussion; I don't have this problem with them...
  1. #136
    targetSTS is offline Cadillac Owners Fanatic
    Automobile(s): 2005 cadillac STS AWD 1SG
    Mar 2011
    33
    372
  2. #137
    PontiacV8's Avatar
    PontiacV8 is offline Cadillac Owners Fanatic
    Automobile(s): 2015 Camaro 2SS, Sold: 2006 STS (EXP) 1997 Seville STS (EXP)
    Dec 2006
    Germany / Nordhorn
    423
    Re: Side marker lights(front fender)
    Quote Originally Posted by Guy.Seminerio View Post
    The vauxhall side repeater LEDs are both leaking. The car is in it's first rain and both of them have a lot of large water droplets on the inside of the lens.
    ...ouch...bad news...
    ...no problems with mine...
  3. #138
    Guy.Seminerio is offline Cadillac Owners Connoisseur
    Automobile(s): '79 coupe deville, '04 Deville DTS White Lightning
    Feb 2013
    Whitestone, NY
    28
    3,211
    Well I'll look into it. I'll get back.
  5. #139
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,482
    That sucks Guy.
    Mine are perfect.
  6. #140
    Feb 2013
    Whitestone, NY
    28
    3,211
    One of the two dried up so I put a silicone seal around the edges. It appeared to be lacking in a couple of spots. I then redid the tape on the back end. And I made sure there was no way for water to get in although I don't think this was the culprit. Then I krazy glued the rubber shell to the light. It was kind of loosely attached previously.
    Rain on Tuesday so we'll see then. Hopefully the other side dries out before then so I can do the same on that side before rain.
  7. #141
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Krazy Glue works best for me with hard surfaces that fit together well.
  8. #142
    Feb 2013
    Whitestone, NY
    28
    3,211
    Well I haven't got the one side to dry out yet but the side I did work on is cured.
  9. #143
    Feb 2013
    Whitestone, NY
    28
    3,211
    Well I haven't updated but I continued to have problems with leaking on both lights. I removed them and reattempted to seal them 3-4 times each to no avail. By the time I was fed up, one of them developed a puddle and I couldn't get the puddle to leak out. This tells me the light was sealed well by now and the condensation was coming from behind (in the fender.)
    Anyway, talked to the vendor and they're very cool about sending me new ones. I'm sending these back.
    What I'd like to do to make sure I don't have this problem again is this: I know you guys said you don't have this issue. Can one of you pull out the light and snap a picture of how you taped up the inside portion to waterproof it?
    I want to make sure I'm doing it right this time (assuming this was my fault which I doubt.)
    Thanks.
  10. #144
    PontiacV8's Avatar
    Dec 2006
    Germany / Nordhorn
    423
    ...an example...see post-# 75 in this thread:
    http://www.cadillacforums.com/forums...l#post10725057
  11. #145
    Feb 2013
    Whitestone, NY
    28
    3,211
    Got it. Thanks.
  12. #146
    Feb 2013
    Whitestone, NY
    28
    3,211
    Well I managed to screw up another pair. I poured automotive sealant down the hole and it leaked into the outside portion (inside the lens) and I assume screwed it all up. It tore up that chrome looking aluminum crap that surrounds the LEDs. The sealant I used wasn't black like the one I see above. So I'd have to order another pair if I care enough to try again. I'll think about it.
  13. Remove Advertisements
