Engine "skips" during acceleration - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
Like Tree4Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Engine "skips" during acceleration in Past Cadillac Vehicle Discussion; Apparently the Amcon station across town is ethanol free, maybe I'll start filling up there....
  1. #16
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,046
  2. #17
    canam0530 is offline Cadillac Owners Member
    Automobile(s): cts 4
    Mar 2014
    31
    1
    Re: Engine "skips" during acceleration
    I have a 2009 cadillac cts4 3.6 direct injected car. the car shudders and hesitates when driving down the road and from accelerating. I have had the car to the cadillac dealer 6 times. the first two times they did a carbon clean out. after the carbon clean out they replaced some spark plugs. when i got the car back the third time it was still doing the same thing, since then i have had the spark plugs changed again, the injectors replaced the fuel rail system replaced the cadilatic converter replaced and coil pack replaced. the car is still doing the same thing not to menetion my gas mileage is horrible. im fed up with this car, any ideas or suggestions please
  3. #18
    CadiTamer is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS 3.6 RWD
    Dec 2013
    22
    117
    That's what my car did when the torque converter began failing. Ended up swapping the entire transmission because the fluid had never been changed in the 126K miles on the car. Problem went away.
  5. #19
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,695
    I understand your frustration due to your current situation, canam0530 and apologize for any inconvenience this has caused. Please feel free to send us a private message that includes your full contact information, VIN, current mileage and dealership name and location so we can further discuss your situation. We are more than happy to contact your dealership on your behalf to discuss the outcome and document your concern and comments within our system which can be accessed by multiple departments at General Motors.
    Sincerely,
    Laura M.
    Cadillac Customer Care
  6. #20
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Have you checked your oil level? If that is right, I'd be surprised if it isn't a coil.
  7. #21
    malatu's Avatar
    malatu is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS 3.6 AWD
    Dec 2005
    1,005
    Quote Originally Posted by Mrsanders3960 View Post
    I always hear about higher octane fuels being waste of money, however in my past i have had 2 cars ruined by cheap gas and ethanol. Since I have changed my fueling habits I have not had these troubles, and with the higher octane (93) I average 22MPG City and about 24 HWY in my 3.6 STS. (Now if go have a little fun all that goes out the window.)
    Do a little reading on what a higher octane fuel is, why it exists and what role it plays in an certain engines (high compression). If you bring yourself to an understanding those concepts, you will be able to make an informed decision as to why you should or should not use higher octane fuel in any particular engine.
    Most often in life, the more more expensive something is, the higher the quality. This is not the case with higher octane fuel! Higher octane fuel is not better fuel, it's just a different kind of fuel. There are lot's of posts here explaining such. Check em' out.
  8. #22
    Daves_05_STS is offline Cadillac Owners Member
    Automobile(s): 05 STS 3.6L
    Apr 2012
    Long Island, NY
    47
    19
    With regard to OP:
    Same issue w/my 05 3.6 RWD. I'll get a check engine flash [always goes away after 30 or so seconds] but, 2x she threw a P0305.
    I like to think this is not the Torque Converter issue.
    I only buy gas at Shell. Did the Chevron Techron thing.
    Coil pack on the way along w/OEM .43 gap plugs.
    My question: Can I get to coil pack 5 without having to do the entire 'tear down'? I'd rather just do the coil pack now, all plugs when it gets warmer. My idle is fine btwn 620-630 and as long as i bby the throttle all rides nice.
    Thanks & BTW the above woes all started after I replaced the paper air filter with a K&N. I was not pleased with the filter fit [flimsy silicon frame vs. rigid plastic]
    I took the entire air box out and made sure the filter was seated properly.
  9. #23
    Neutrocuted's Avatar
    Neutrocuted is offline Cadillac Owners Fanatic
    May 2010
    457
    I have the same thing going on, no codes, and I use premium from Sam's. I also notice occasional mild engine stumbles while idling in gear at a stop light. Guess it's time for some top tier and some cleaner!
  10. #24
    KRSTS Guest
    Why would you use "premium" in a 3.6 ?
  11. #25
    C&C's Avatar
    C&C
    C&C is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac XT5 (2017)
    Feb 2008
    Mount Pleasant, SC
    66
    1,939
    Post #22 'Daves...' Since your problem can be related to installing the K&N:
    While not rampant (I've used K&N and have never had a problem), but if the filter is over-oiled and through induction some of that oil leaves the filter and gets onto the MAF sensor, you may experience some drive-ability problems. They make a MAF sensor cleaner that you may want to try (making sure the filter isn't yielding any oil in use).
  12. #26
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    The OEM filter flows better and protects your engine better and cheaper than K & N.
  13. #27
    malatu's Avatar
    Dec 2005
    1,005
    Quote Originally Posted by KRSTS View Post
    It costs more so it should be better for my car, right?
    Guy.Seminerio likes this.
  14. #28
    STS 2005 is offline Cadillac Owners Member
    Dec 2013
    17
    For the 6 cylinder you can get to number five easily by just pulling the top shroud, couple bolts to take off under that but easy. I did the coil pack and plug when i was getting the code and dash light flashing under accelerating hard. It helped for a while but the problem came back..
    Number five is rear by the passenger side
  15. #29
    Apr 2012
    Long Island, NY
    47
    19
    THX STS 2005. I removed the top shroud/cover just earlier. Aside from one harness, CYL5 on the 3.6L is practically looking at you.
    ....also thinking about ditching the K&N air filter.
    Coil replaced: 10 mins and a 10MM socket = NO MORE FLASHING CEL AT HARD/GRADUAL ACCELERATION!!
    I left the K&N air filter installed as that would have been a poor troubleshooting technique.
    ...now if i could only get my gas mileage back up to 19.9MPG [from this pathetic 19.1]
    Cheers
  16. Remove Advertisements
