Trunk switch replacement
Results 1 to 5 of 5
Cadillac STS Forum - 2005 through 2012 Discussion, Trunk switch replacement in Past Cadillac Vehicle Discussion; I ordered a new trunk switch for my 2006 Sts. The rubbery button on the outside did not engage the ...
    bighouse427 is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac STS4 V6
    Jan 2012
    37
    1
    I ordered a new trunk switch for my 2006 Sts. The rubbery button on the outside did not engage the trunk release anymore. Any one know how to replace it and is it hard? Thanks
    Brianjetski is offline Cadillac Owners Member
    Automobile(s): Cadillac STS4
    Oct 2007
    Wisconsin
    12
    Re: Trunk switch replacement
    My decklid switch is also not working, anybody know how to replace it?
    FattyCaddyCtsV is offline Cadillac Owners Member
    Automobile(s): 2004 Cadillac CTS-V
    Aug 2013
    30
    40
    Are you talking about the release switch?
    This?
    http://gmpartsonline.net/parts/2005/...lease%20switch
    Just want to make sure you don't mean the actual hardware/latch...
    There's a lot of advice here btw
    http://www.cadillacforums.com/forums...t-working.html
    Ludacrisvp's Avatar
    Ludacrisvp is online now Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,548
    could be the antenna and not the switch...
    dannyquest is offline Cadillac Owners Fanatic
    Mar 2012
    columbus ohio
    382
    bighouse427, Mine was easy. The clips that hold it in rusted and the switch fell out. Just unplug the attached wire & push the new switch into place. The clips are attached to the switch and will spring out when pushed into the opening. It may a little tough to spring back the clip while the switch is still in the car. I then split the old switch to see inside. Four spring contact push onto a flat copper plate which had thin white coating. I used steel wool to polish the copper plate. Reassembled & tested by connecting to the plug at the trunk deck, work fine. Still installed the new switch. Part# 10383948, $25. plus shipping thur Rippy's Danny
  8. Remove Advertisements
