Dash
Results 1 to 7 of 7
Cadillac STS Forum - 2005 through 2012 Discussion, Dash in Past Cadillac Vehicle Discussion; Would the instrument cluster from a 2007 2008 srx fit and work in an sts. I see that it's the ...
    B1n2fra's Avatar
    B1n2fra is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 1SG STS v8 awd
    Nov 2011
    Chicago
    36
    502
    Dash
    Would the instrument cluster from a 2007 2008 srx fit and work in an sts. I see that it's the same exact cluster but with just blue led instead of the sts orange color. Are the connections different?
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Try it.
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,785
    Re: Dash
    The wiring harness connector is the same physical part but they are not wired identically. There are three additional signals connected to the SRX cluster that are not present on the STS. This doesn't necessarily mean it won't work but you also have to consider the programming. I don't know if things like lane departure warning was available on the SRX so if you have it on your STS, it may not work (as an example). There may also be some differences in the messages displayed on the DIC. It could be difficult to know for sure if it's 100% compatible.
  5. #4
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,482
    Could be interesting to know.
  6. #5
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,176
    Re: Dash
    Stuff like milage is store in the dash so a replacement would require shipment to an electronic component service center to have the data synchronized.
    Don't mess with Binky Bear!
  7. #6
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,482
    Re: Dash
    No point to send it out to be programmed if it doesn't work. I would try to connect it and see what happened before sending it anywhere.
    You might just be able to swap the display unit only rather than the whole cluster.
  8. #7
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Dash
    I predict a long and spendy road ahead.
    Have fun & send us a post card!
  9. Remove Advertisements
