JE5 Brake Replacement
Results 1 to 6 of 6
Cadillac STS Forum - 2005 through 2012 Discussion, JE5 Brake Replacement in Past Cadillac Vehicle Discussion; I purchased a set of brakes from a retailer whom I will not mention yet... Not until I know whether ...
    kschwed is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Cadillac STS 1SC
    Nov 2009
    California
    28
    383
    I purchased a set of brakes from a retailer whom I will not mention yet... Not until I know whether or not they are going to make this right.
    I have JE5's. I purchased rotors from them and they do not fit on the front. I haven't tried the back yet.
    Basically, the rotors are exactly the same size, 12.6" I believe. The problem lies in the hub of the rotor. The diameter is too wide so the caliper shoe won't fit correctly. it need about another 1/2".
    They want my Vin, Date code from the door, and the OEM part numbers from my ac delco rotors.
    I don't know the OEM #'s from my JE5's. Does anyone have these?
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: JE5 Brake Replacement
    My brake guy had to return one set of rotors. Evidently, some aftermatket cross-reference information is imperfect.
    Good luck!
    sapien's Avatar
    sapien is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS V8
    Jan 2008
    Woodbridge, VA
    165
    I measured an OEM JE5 rotor:
    12-11/16" outer diameter
    7-3/4" inner diameter (back hub opening)
    1-1/4" thickness
    CADDYBLACK99 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-4 1999 Deville Concours
    Oct 2003
    NEW ENGLAND
    58
    1,486
    Quote Originally Posted by EChas3 View Post
    Good luck!
    That also happened to me. If to use AutoZone and you have JE5 (Performance Brakes) you need 12.72 inch rotor (323.0mm) Part #55105.
    Their website suggests 55096 for cars with 17" wheels which is correct for JL9, but their site should be corrected to offer the larger rotor for the JE5 performance brake upgrade (also with the 17" wheels). Be careful!
    sub613's Avatar
    sub613 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 STS 1SF N* RWD NAV F55
    Mar 2009
    NC for Now, Florida SOON
    704
    CoolRe: JE5 Brake Replacement
    I Now how this sounds, but, did you compress the piston
    before trying to install the caliper ?
    You did not mention that in your post .
    Both the JL9 and JE5 are about (close)the same thickness !
    Not a 1/2" difference.
    Just asking !
    PEACE
    Good Luck
    Oct 2003
    NEW ENGLAND
    58
    1,486
    The answer is yes the pistons were compressed fully. After taking the first set of pads off, I discovered that the pad had a .25-.50" ridge along the top of the pad that the rotor had cut into it. That is when I stopped and cross referenced the rotor diameter of the JE5 (12.72") and the JL9 (11.92") and discovered that I had the wrong rotor.
    Thanks Subsailor613 for pointing out that I did not mention I had completed that step. We all learn from our mistakes and that was one mistake I had made last time I changed pads
  9. Remove Advertisements
