Torque Bolt Specs - 2005 STS V6
Results 1 to 4 of 4
Like Tree2Likes
  • 2 Post By scott9001
Cadillac STS Forum - 2005 through 2012 Discussion, Torque Bolt Specs - 2005 STS V6 in Past Cadillac Vehicle Discussion; Hello, I am hoping someone out there is able to help me get torque wrench settings for a few bolts. ...
    YuhSeet is offline Cadillac Owners Member
    Automobile(s): 3.6L V6 2005 STS
    Nov 2011
    32
    3
    I recently had an embarrassing, rather annoying noise coming from under my 05 STS V6 RWD 64,000+ miles. It's a whooping/rubbing noise any speed over 25MPH which I discover makes a more consistent noise when I'm making a left turn or corner (noise tends to go away when I make right turns).
    I took it to the dealer while I was getting an oil change and they said I have a bad left front wheel bearing/hub. They wanted $880 to replace 1 & $1450+ tax to replaced both. I opt to research cheaper alternative which I was able to order 2 from GM parts direct for waaaaay cheaper. I plan on installing it myself at a buddy's workshop.
    I've been reading through these forums but I haven't come across a forum post for the specs on torque setting for the HUB bolts, brake caliper bolts, lug nuts, or anything around the suspension area. If someone could guide me into the right directions, I'd greatly appreciate it. Thanks in advance.
    p.s. [All 4 Tires are new - under 4 months old]
    scott9001 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 sts N* 1965 coupe deville
    Aug 2011
    26
    364
    Re: Torque Bolt Specs - 2005 STS V6
    wheel bearing hub to knuckle bolts-92ftlbs
    front axel nut-118ftlbs
    front caliper bridge bolts- 92ftlbs
    caliper pins JE5- 25 ftlbs -JL9-46 ftlbs
    YuhSeet and YuhSeet like this.
    Nov 2011
    32
    3
    Quote Originally Posted by scott9001 View Post
    Thank you very much, I really appreciate it. I will be tackling this project this coming weekend before 4th of July week so I can make a trip.
    Aug 2011
    26
    364
    no problem btw the wheel nuts are 100 ftlbs
  7. Remove Advertisements
