timing chains
Page 1 of 3 123 LastLast
Results 1 to 15 of 39
Like Tree4Likes
Cadillac STS Forum - 2005 through 2012 Discussion, timing chains in Past Cadillac Vehicle Discussion; ...
    Jerry Grass is offline Cadillac Owners Member
    Automobile(s): 2005 SRX
    Jun 2012
    3
    timing chains
    I found this forum Friday after my wife picked up her car, a 2005 SRX, from the Dealership after having the timing chains replaced. I am sure this will be the last Cadillac I will purchase (I have owned several). I will certainly let my friends know about the built-in defect that Cadillac’s have that I discovered here.
    The car has 84,000 miles, is garage kept, has been maintained according to the manual. If the car had 125,000 miles or more this would not have been a surprise.
    I see that Cadillac has recognized they have a problem by giving an additional warranty on the 2007 SRX. Why have they not extended the warranty on all model since this is their fault.
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,063
    Because 06s and older are out of warranty...I will never buy another GM 3.6 again...hence why I got the N*. A timing chain going out should always be a surprise as they are supposed to be good for the life of the vehicle...timing belt, now that's expected to need replacement around 100k.
    jimmbo is offline Cadillac Owners Fanatic
    Automobile(s): 2008 sts, 1995 Brougham V4P
    May 2009
    225
    Re: timing chains
    Anything with a 3.6 DI should be covered up 192,000 km(120,000 miles) or 10yrs, I don't know about nonDI engines. The real problem is how GM skimped out on the chains. They look flimsier than the ones on a bicycle. Ba$tards
    Loren is offline Cadillac Owners Member
    Automobile(s): 08 STS
    Jan 2009
    90
    Re: timing chains
    I got a letter from Cadillac last week telling me my warranty on the timing chain is 120,000 miles or 10 years from the date it was originally put in service. I had previously had the ECM reprogrammed to prevent premature wear as a result of another letter they sent me last year.
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,063
    The issue is not the chain, it's the crap shoot of a PCV system, or lack there of...the vent orifice clogs, then oil gets sucked into the intake, causing the crankcase to be low on oil...all 3.6 owners should check their oil religiously...
    May 2009
    225
    Re: timing chains
    Yeah the reprograming drops the oil change interval to about 5500 miles using Mobil 1.
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,063
    I did 5k intervals with my CTS, didn't care what the OLM said.
    kschwed is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Cadillac STS 1SC
    Nov 2009
    California
    28
    383
    Re: timing chains
    So what exactly is the issue with the timing chains? I check my oil because I notice that I burn through it. Is there a way to fix that?
    May 2009
    225
    Re: timing chains
    The skimpy little chains that Gm used as timing shains are stretching. This is causing the valve timing to alter enough that the engine will not be able to meet emission targets. It triggers a code.
    Nov 2009
    California
    28
    383
    Re: timing chains
    What is the relationship between these chains and burning through oil? And can the timing chain issue be avoided by keeping oil levels at an optimum level?
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: timing chains
    Most are fine. The 3.6 was new. The DI, tensioner changes and supplier changes didn't help.
    Look at all the issues that crop up a few years into production of most new designs. Even the best have some failures. As designs become obsolete, they are often finally perfected.
    I love the STS Northstar.
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,063
    Re: timing chains
    Quote Originally Posted by EChas3 View Post
    I 2nd that! I loved my FWD N* in my 2001 STS, but the RWD revision is even better!
    prospyder is offline Cadillac Owners Member
    Automobile(s): 2007 Silver STS V6, 1990 Red Allante
    Mar 2009
    Webster Groves, MO
    64
    Re: timing chains
    I just had my 07 STS V6 in for the 30k mile service. Two days before the appt at the Cadillac dealer, the engine light came on steady. When I called the service advisor, he said it was OK to drive in for service as long as the light was steady, which it was. After checking the car, the service advisor told me the timing chain had stretched and would be replaced under warranty. (I had previously had a problem with the car not starting in January due to carbon build up -- I was told by the service advisor it was common in low-mileage cars -- which cost me $213 since it was considered a maintenance item! -- see another thread I posted on that. It was not covered under the GMPP I purchased in Dec of last year!)
    After a day and a half in the shop, the car was "ready." I noticed a knocking or rattling sound right after starting the car a day after I picked it up, so took it back to the dealership. I suspected a problem with the newly installed timing chains. After another day in the shop, I got ahold of the service advisor who told me one of the chain tensioners was not working properly and it would take another day to repair, I finally have the STS back but I'm now conerned that another stretched timing chain may occur in anther 30,000 miles.
    I will not use the Cadillac dealer that did this work for service again, but aside from that, I'm not sure if it's wise to keep the STS. (I had planned to keep until 60,000 miles.) Are the timing chains used to replace the OEM chains of better quality or can I expect another premature chain stretch/failure?
    JEP
    Kirkwood, MO
  16. #14
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    If your worried about it shoulda bought the bulletproof n* v8
    spike1040 likes this.
  17. #15
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,063
    that's why I didn't get another
    3.6, heard too many horror stories when I had the CTS...
  18. Remove Advertisements
