Headlight assembly condensation solutions - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 48
Like Tree5Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Headlight assembly condensation solutions in Past Cadillac Vehicle Discussion; Yeah was told several times its normal everything that is wrong is normal, nothing like a Cadillac or their service. ...
  1. #31
    Surfstix is offline Cadillac Owners Fanatic
    Automobile(s): 2016 XTS Premium
    May 2012
    Hampstead NC
    129
    Re: Healight Condensation Solution Thread
    Yeah was told several times its normal everything that is wrong is normal, nothing like a Cadillac or their service. I'm just about done with GM as much as that hurts to say I just cannot get any satisfaction 3 dealers later school for the techs must be a cinch just tell them its normal and we will cover our asses.GM
  2. #32
    JakeBanman is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac CTS, 2001 Cadillac Eldorado (2012-2014)
    Oct 2012
    Manitoba, Canada
    27
    4
    When I had water pooling in my passenger sidelight (which was brand new); the shop told me that the manufacturer didn't SEAL the two sides together fully; there was about an 1 1/4" long strip that was not sealed and that was causing the leak.
    They used a marine epoxy like compound to seal it so it wont dissolve on rainy days and so far, it's dry as a bone!
  3. #33
    tbreezy is offline Cadillac Owners Member
    Dec 2012
    11
    [/COLOR]
    Quote Originally Posted by Carvone
    I have the same problem on my '07, mine looks just like "curtc" pics. When I bought the car there was water in the lenses so I took the the front of the car off, took apart the lenses, cleaned and polished it all and resealed both. The are nice an dry now but still have that "grainy look". It is on the inside of the lens too, doesn't make sense but it is. There is no way it is worth the cost of replacement so I live with it.
    I have an 07' as well and I am having the same water problem. How and what parts did you re-seal?
  5. #34
    james6speed's Avatar
    james6speed is offline Cadillac Owners Fanatic
    Automobile(s): '07 STS 1SG ~ '13 Sonic RS Turbo ~ '87 944 Turbo
    Nov 2013
    117
    Quote Originally Posted by 1BadCadSTS View Post
    You can remove the side doors by pulling the air box for left lamp and the fuse box for right lamp.
    1BADSTS,,, so let me get this straight, you can remove the pass. side fuse box, then remove this side cover from there without removing headlight and bumper?
    Is this where you double-taped the silica pads to, inside the side cover?
  6. #35
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Quote Originally Posted by james6speed
    Correct. Not fun if you have big hands haha but I managed just fine.
  7. #36
    Nov 2013
    117
    probably can't get a hairdryer in either ehh? Or would the silica bags take care of it?
  8. #37
    Nov 2013
    117
    So the front is not removable??? See picture for what I mean.
  9. #38
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    If you bake it in an oven and pry it apart.
  10. #39
    Roger O'Dell is offline Cadillac Owners Member
    Automobile(s): 2005 sts2007 xlr v1941,1947,1948 sedenettes,1957 seville,195
    Nov 2009
    Canyon Lake, Ca
    70
    26
    Re: Headlight assembly condensation solutions
    I complained to the dealer while still under warr, but the said they could not duplicate, and I polishes the exterior with aircraft grade windshield polish, looked good for quite awhile but starting to haze again 2005 sts just past 140000mi.
  11. #40
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Warranty only covers 'excessive moisture'. About five years ago it was a very popular forum topic. Members schooled those reporting the issue to always repeat 'excessive moisture' at least twice during every conversation with Cadillac and dealer representatives.
    It did seem to improve the odds of coverage and provided a negotiating position. Cadillac is very proud of that headlight assembly. If I had a bad one and could get it replaced for the cost of labor, I'd consider that a pretty sweet bargain.
  12. #41
    Nov 2013
    117
    out of warranty, so no dice for me
  13. #42
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,559
    Quote Originally Posted by james6speed View Post
    As most of us likely are these days...
  14. #43
    tealBehindthwheel is offline Cadillac Owners Member
    Automobile(s): 2005 sts4
    Apr 2013
    Nashville TN
    13
    hey guys, how do you remove the lenses off the front? I tried using a heat gun and so far it's just melting the plastic and not giving any way.
  15. #44
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Quote Originally Posted by tealBehindthwheel
    Never do it that way Bake in oven PREHEATED to 225 deg for 15 minutes.
  16. #45
    Apr 2013
    Nashville TN
    13
    and does the front just pop off or do i need to pry it off or what needs to be done?
  17. Remove Advertisements
