Service Stability and ABS lights/warning come on
Results 1 to 3 of 3
Cadillac STS Forum - 2005 through 2012 Discussion, Service Stability and ABS lights/warning come on in Past Cadillac Vehicle Discussion; What causes this? Anything I can do to fix it? Thank you!...
    LiquidTrader is offline Cadillac Owners Fanatic
    Dec 2011
    152
    Thank you!
    salvie is offline Cadillac Owners Member
    Automobile(s): 2008 STS 4
    Jun 2011
    48
    30
    Re: Service Stability and ABS lights/warning come on
    Same on my 08 AWD...it was a rear hub bearing...under warrenty
    scott9001 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 sts N* 1965 coupe deville
    Aug 2011
    26
    364
    ^ what he said probably a bad wheel speed sensor or a wheel bearing not a big deal plug in with a scanner and read some codes should help you out alot there
