Oil burn
Results 1 to 11 of 11
Cadillac STS Forum - 2005 through 2012 Discussion, Oil burn in Past Cadillac Vehicle Discussion; I have a 2005 STS v6 with 66,000 miles, it started using a quart of oil every 2,000 miles. Anyone ...
    Harley04 is offline Cadillac Owners Member
    Automobile(s): 2005 STS
    Jun 2012
    Illinois
    54
    4
    Oil burn
    I have a 2005 STS v6 with 66,000 miles, it started using a quart of oil every 2,000 miles. Anyone else have this issue?
    KRSTS Guest
    Re: Oil burn
    according to GM that's within normal range for that engine
    Jun 2012
    Illinois
    54
    4
    Re: Oil burn
    That can get expensive, $70 for oil change and $9 a quart to add in between changes!!
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,033
    I paid $56 for a 6qt. Mobil 1 oil change at my local GM dealer for my 3.6l CTS...OP, how does your intake look? Full of oil? It's the "PCV" orifice on the passenger side valve cover...gets plugged up and then oil gets sucked into the intake...have you looked into an oil catch can? This is why the 3.6l engines like to blow timing chains...GM design flaw.
    Jun 2012
    Illinois
    54
    4
    Re: Oil burn
    Thanks for the info, I'll check that out.
    dannyquest is offline Cadillac Owners Fanatic
    Mar 2012
    columbus ohio
    382
    Re: Oil burn
    Harley04, Here the scoop. My 06 STS V-6 was burning oil at rate of 1qt. @ 760 miles. Lucky it was under warrenty. Cadillac replaced the piston rings. Now 30,000 miles later still burns no oil. You could add 1 qt. of oil every 2,000 miles and never have to change oil again. Danny
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Oil burn
    ^^^ Not so. Oil breaks down & gets dirty. Do what the OLM says.
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,033
    I do no more than 5k between changes, no matter what the OLM says.
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Oil burn
    That's a waste of oil, but it's your money. Enjoy!
    Jun 2012
    Illinois
    54
    4
    Re: Oil burn
    Any recommendations for a brand of oil catch can?
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,033
    Was there oil in your intake? The catch can doesn't keep the oil in the crank case, just keeps it from going into the intake. Poke around the 1st gen CTS forum regarding this, TONS of info...
  14. Remove Advertisements
