Car takes off at end of gear.
Results 1 to 7 of 7
Cadillac STS Forum - 2005 through 2012 Discussion, Car takes off at end of gear. in Past Cadillac Vehicle Discussion; Ive recently noticed that I have a slight power loss sometimes when I slam on the gas from 0, and ...
    B1n2fra's Avatar
    B1n2fra is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 1SG STS v8 awd
    Nov 2011
    Chicago
    36
    502
    Ive recently noticed that I have a slight power loss sometimes when I slam on the gas from 0, and the car seems to be turbo charged or something towards the end of each gear. When it reaches the end of the gear the car feels as if a turbo had kicked in and the car fly's like a bat outta hell. Even if the throttle's not pressed all the way down the car takes off. I also notice a slight hiss in the front right side of the engine. I thought maybe a hose was loose but I cant see anything. I noticed both of these things around the same time. Is there any vacuum hoses in that general area that I should look for that could play with the acceleration of the car. 07 awd N*
    B1n2fra's Avatar
    Nov 2011
    Chicago
    36
    502
    Re: Car takes off at end of gear.
    Any ideas anybody???
    MacMuse is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS N* 1SE
    Feb 2009
    Chicagoland
    54
    2,399
    Nothing to offer other than my dealer cleared some light hesitation when found and repaired a couple vacuum issues while working on something else.
    Yeah, just recommending a dealer check with the official diagnostic systems.
    Lifer's Avatar
    Lifer is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 Cadillac Eldorado ETC
    Apr 2007
    Coppell, TX
    905
    Check your intake manifold bolts. They loosen up and could cause this.
    B1n2fra's Avatar
    Nov 2011
    Chicago
    36
    502
    Is the intake manifold the black plenum plastic piece on top the engine
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    That's when peak hp hits on the n*. Its a high rev dohc engine. The gearing helps on take off it's high rpm band and peak power take over when over 5k rpm.
    B1n2fra's Avatar
    Nov 2011
    Chicago
    36
    502
    It has to be the intake bolts. I tightened a few that I could reach and I noticed a difference . And if I'm just cruising at about 1200 rpm not giving it much gas at all when it reaches the end of the gear it just shoots off as if I hit the gas harder. I sometimes have to pull my foot off of the gas to gain control.
  10. Remove Advertisements
