07 sts head light issue
Results 1 to 7 of 7
Cadillac STS Forum - 2005 through 2012 Discussion, 07 sts head light issue in Past Cadillac Vehicle Discussion; I have 07 STS with halogen lights. I've noticed that the head light don't reach far enough. My friends also ...
    Tapas0514 is offline Cadillac Owners Member
    Automobile(s): 2007 STS
    Jun 2011
    6
    I have 07 STS with halogen lights. I've noticed that the head light don't reach far enough. My friends also told me same thing. When I talked to dealer to look at it they said its covered under my warrant but they can't fix it because projector lens can't be adjusted. I also have cts but that light is perfectly fine. Please help.
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Angle them up then. You can adjust them vertically just not horizontally.
    Jun 2011
    6
    I'll look at it if I can on my own. Cadillac service department said it can't be done.
    JimmyH is offline Cadillac Owners 10000+ Posts
    Dec 2006
    42
    37,302
    Re: 07 sts head light issue
    moved from cust svc
    sub613's Avatar
    sub613 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 STS 1SF N* RWD NAV F55
    Mar 2009
    NC for Now, Florida SOON
    704
    CoolRe: 07 sts head light issue
    Look Under the hood , near the headlights, there is a funnel shaped piece facing UP,
    on each side, that is the adjuster for the headlights, LOW & High !
    turn it to tighten, (IN) about 4 turns, and check at night if it's OK . Adjust accordingly.
    I think I used a Phillips, NOT sure .
    Good Luck
    Jun 2011
    6
    Thanks!
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,033
    Or swap out those halogens with an aftermarket HID conversion kit...Had the same problem in my 2001 STS...The HIDs made a dramatic difference.
  10. Remove Advertisements
