BATTERY test
Results 1 to 3 of 3
Cadillac STS Forum - 2005 through 2012 Discussion, BATTERY test in Past Cadillac Vehicle Discussion; Had problems with STS with Tranny shitfing and battery died about two weeks ago car is fine now. Never found ...
    JAYRAT is offline Cadillac Owners Member
    Automobile(s): 07 STS V8
    Nov 2011
    NEW MEXICO
    49
    BATTERY test
    Had problems with STS with Tranny shitfing and battery died about two weeks ago car is fine now. Never found out what cause was. Did rain for about 3 days water puddles were deep. Since then car has started real rough idle for about 30 secs to one minute on initial start,after that car runs and starts right up smooth. Did notice when i put pedal to floor don't feel like it gets all power like it used to. I cleaned throttle body, MAF sensor, and fuel injectors. Manifold bolts good and torqued proper,No CEL light. Question is what if i disconnect battery and maybe it will reset or help it somehow. I have exhausted all means, shop hooked diagnostic showed no history. Anybody out there Cadillac guru?
    sub613's Avatar
    sub613 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 STS 1SF N* RWD NAV F55
    Mar 2009
    NC for Now, Florida SOON
    704
    Re: BATTERY test
    Have experienced similar problem (ONCE).
    Got out of grocery store, got in, pushed start button, NOTHING.
    got out, checked mattery voltage, OK
    Tried to start car with remote, I think it started OK, resumed
    normal car stuff, NEVER HAPPENED AGAIN.. ???????
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: BATTERY test
    Right after purchasing my 2006 I began having issues that ending up being the result of stressed wiring at the throttle-body controls. The codes suggested the throttle pedal. The repair required was at the other end.
