Lifting up intake manifold help for 05 Cadillac STS V6
Results 1 to 5 of 5
Cadillac STS Forum - 2005 through 2012 Discussion, Lifting up intake manifold help for 05 Cadillac STS V6 in Past Cadillac Vehicle Discussion; Hey guys, I have a 2005 Cadillac STS V6 and I need to replace the #3 spark plug and ignition ...
    KingMack is offline Cadillac Owners Member
    Automobile(s): 2005 STS 3.6L V6
    Mar 2011
    30
    43
    Hey guys,
    I have a 2005 Cadillac STS V6 and I need to replace the #3 spark plug and ignition coil which the intake manifold is sitting right on..how do I go about lifting that up just enough to change these units? I removed the four bolts on top of the manifold, where are the others if the are any?? I did a lot of research and it seems like this is what has to be done for the V6 2005 STS but I didnt really find much about doing that. Please help!
    Thanks,
    King
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Lifting up intake manifold help for 05 Cadillac STS V6
    Got the shop manual or access to AllData? Members that work on their own cars generally do.
    Now that the weather is improving, the forum is slowing down some. I'd expect a DIY'er to post within a day or two.
    Mar 2011
    30
    43
    Thanks for responding I was able to replace the coil but didnt know how to get the spark plug out of that deep hole. If someone could respond on helping me with that I would be thankful. Is there a tool I need?
    Thanks,
    King
    fly187's Avatar
    fly187 is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac STS4
    Jun 2012
    Dallas Texas
    38
    84
    you need a spark plug socket and about a 6 inch extension. It has a rubber garment inside socket to hold spark plug. Or you can, use a regular deep socket to loosen, then stick a magnetic rod to pull plug out.
    scott9001 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 sts N* 1965 coupe deville
    Aug 2011
    26
    364
    you also should not install the spark plug with a regular socket because a spark plug socket is designed to hold the plug straight where a regular one is not therefore you will be more likely to crack the porcilyn causing a misfire.
  8. Remove Advertisements
