JE5 Brake Replacement
Results 1 to 5 of 5
Cadillac STS Forum - 2005 through 2012 Discussion, JE5 Brake Replacement in Past Cadillac Vehicle Discussion; I'm going to replace all 4 pads and rotors. I believe my fronts are warped - they are extremely shaky ...
    kschwed is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Cadillac STS 1SC
    Nov 2009
    California
    28
    383
    I'm going to replace all 4 pads and rotors. I believe my fronts are warped - they are extremely shaky and have already been turned once. Either way, I want some suggestions on which rotors/pads to use for the JE5 system. I don't need the top of the line, but I am not impressed with the AC Delco stuff I've had.
    Also, I've never done brakes on this car before, so some tips/pictures/walkthrough would be great.
    Thanks
    malatu's Avatar
    malatu is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS 3.6 AWD
    Dec 2005
    1,005
    Re: JE5 Brake Replacement
    They may not be warped. It could be foreign material "build up". There was quite a lengthy thread a couple of months ago on the subject. I thought it was quite interesting as well as informative.
    http://www.cadillacforums.com/forums...ed-rotors.html
    I assume you know that once the rotor's thickness is cut beyond the minimum, you have to replace.
    Try Frozen Rotors. I put a pair on my wife's daily driver a few years ago. They've performed flawlessly. Though they weren't cheap.
    dkozloski's Avatar
    dkozloski is online now Cadillac Owners 10000+ Posts
    Jul 2004
    Fairbanks, Ak
    28,210
    I just replaced my front JE5 brakes. I used NAPA Ultra-Premium rotors and Adaptive-One pads. Now when I apply the brakes it feels like the hand of God has reached out and grabbed the car. They couldn't be smoother. All you need is a floor jack, some jackstands, a couple of wrenches, a torque wrench, a set of torx drivers, a big C clamp, a medium sized C clamp, and some red and some blue Lock-Tite. Everything else you need to know is in the Factory Service Manual.
    Don't mess with Binky Bear!
    sub613's Avatar
    sub613 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 STS 1SF N* RWD NAV F55
    Mar 2009
    NC for Now, Florida SOON
    704
    I've done mine twice, and a Ratcheting breaker bar,and Metric sockets
    are recommended, and torquing the Lug nuts to 95 ft.lbs. is also
    recommended, as to NOT warp the rotors.
    A little lube on the sliders, and stickey on the back of the pads is a
    great brake job. I used Performance Brakes, drilled & Slotted Rotors(Black).
    Have fun ! Good Luck !
    scott9001 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 sts N* 1965 coupe deville
    Aug 2011
    26
    364
    Quote Originally Posted by Subsailor613 View Post
    hey where did you get your rotors and any noise problems?
  8. Remove Advertisements
