2005 3.6 jumping @ WOT
Results 1 to 5 of 5
Cadillac STS Forum - 2005 through 2012 Discussion, 2005 3.6 jumping @ WOT in Past Cadillac Vehicle Discussion; New to the site. My 2005 has been burning a lot of oil. I have already come across the air ...
    onlygm's Avatar
    onlygm is offline Cadillac Owners Member
    Automobile(s): 2005 STS, 2012 CTS4
    May 2012
    Downers Grove, IL
    53
    1
    New to the site. My 2005 has been burning a lot of oil. I have already come across the air cleaner problem and the fact that they just burn oil.
    The real problem I have is from a dead start and then WOT the car will jump up then drop to nothing and back to WOT. I didn't look at the tach but I am guessing around 1800-2400 then 600 and back up and down. It also seamed to do it from a smooth 35 mph, and going WOT just didn't feel right ??
    Drives fine for my wife. (Light foot)
    90K miles 3.6 L RWD
    No codes show up with my Accutron reader
    Bad fuel pump wouldn't show so fast I don't think ??
    fuel filter ??
    Clogged Catylist?
    ECU ???
    Throttle position ??
    I will post a Video if it will help.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: 2005 3.6 jumping @ WOT
    Press and hold the traction control button for five seconds to turn it off. Still the same?
    Excessive oil use is not normal. How many miles are on the car?
    truckinman is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Cadillac STS 3.6
    Apr 2012
    Columbus OH
    31
    1,219
    It says 90k miles in his post chase. Would it be blow by? Far as the oil loss is concerned?
    dannyquest is offline Cadillac Owners Fanatic
    Mar 2012
    columbus ohio
    382
    onlygm, I have a 06 STS V6, 48k. Was burning a quart of oil every 760 miles under Cadillac test. There test is they change the oil, I drove 2000 miles. Under warrenty the piston rings were replaced. Done some reseach and found out the new piston rings are not the same and have a differant part number. 30,000 miles later uses no oil. Unless you rering the engin, buy stock in oil. Danny
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Gimmee an obsolete N* any day.
  8. Remove Advertisements
