Rear Suspension replacement question.
Results 1 to 11 of 11
Like Tree1Likes
  • 2 Post By EChas3
Cadillac STS Forum - 2005 through 2012 Discussion, Rear Suspension replacement question. in Past Cadillac Vehicle Discussion; I have a 2005 STS N* with the magnetic ride control. I have a leak in the right rear shock ...
    shortfur7's Avatar
    shortfur7 is offline Cadillac Owners Fanatic
    Automobile(s): 2014 ATS4 2.0
    Jul 2011
    31
    143
    I have a 2005 STS N* with the magnetic ride control. I have a leak in the right rear shock in the actual metal where it has rusted through a pin hole. im trying to find replacements for them but am having a hard time locating them. Can i get any replacement air shocks and re route the air lines(reason i ask that is my compressor is bad and not working for them anyways) or am i screwed and have to buy the OEM ones since i have the magnetic ride control? Or is there some aftermarket of some sort i can use
    Any help would be greatly appreciated.
    Thanks
    B1n2fra's Avatar
    B1n2fra is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 1SG STS v8 awd
    Nov 2011
    Chicago
    36
    502
    I've found aftermarket shocks but they cost just as much or even more than the actual oem shocks. Your best very is ebay or gmpartsdirect.com. Auto parts stores don't carry many parts for the sts. You can buy some aftermarket shocks without the fe3 option but the car would retain its original ride height unless you changed the springs. I have a leak in the same spot on the left side so I know.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Rear Suspension replacement question.
    Get a quote from Chris at Rippy's before you buy.
    mckellyb and mckellyb like this.
    shortfur7's Avatar
    Jul 2011
    31
    143
    Quote Originally Posted by EChas3 View Post
    Who is this Chris?
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Chris is the guy that often sells OEM parts at the best prices. Rippy Cadillac is a dealer in Wilmington NC.
    B1n2fra's Avatar
    Nov 2011
    Chicago
    36
    502
    Its funny how right after responding to this post my compressor stopped working. Now my rear end is sagging. Have new shocks on the way but now I gotta find a compressor. Can a aftermarket compressor be retro fitted into its place. I have oem fe3 replacement shocks.
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    I recently had mine replaced under a Zurich Warranty repair; $100 deductable; warranty paid $800.
    Check Chris's price.
    shortfur7's Avatar
    Jul 2011
    31
    143
    Quote Originally Posted by B1n2fra View Post
    I found the OEM Rear shocks for $468 a piece and the OEM compressor with air lines for $375. I think im just going to buy the whole new OEM setup since its about the same as buying the aftermarket shocks from ebay.
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Make sure they are the right ones for your car. There are two designs for MRC & Non-MRC
    B1n2fra's Avatar
    Nov 2011
    Chicago
    36
    502
    Quote Originally Posted by shortfur7
    Ebay has the parts cheaper than that. And gmpartsdirect.com
    Ebay has the shocks for 377.00 each and the air compressor is about the same. Can't find one cheaper. Best bet if you don't get all the parts at the same time get the shocks first..
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    I'm not sure the compressor is the same. I've read here that the metering is different. Naturally, the shocks are.
  14. Remove Advertisements
