Northstar Coolant Hose Kit?
Results 1 to 5 of 5
Cadillac STS Forum - 2005 through 2012 Discussion, Northstar Coolant Hose Kit? in Past Cadillac Vehicle Discussion; Do they make a cooling hose kit for the Northstar? I was out replacing my air filter this evening, and ...
    orange57's Avatar
    orange57 is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 STS Northstar RWD
    Nov 2010
    Phoenix, AZ
    34
    511
    Do they make a cooling hose kit for the Northstar? I was out replacing my air filter this evening, and doing a look over of everything, and noticed that I have a small leak at one of the hoses, leaking past the clamp. The car is going on 7 years old, and I will be doing the coolant flush in the next couple of weeks before the summer heat gets here, if they make a kit that replaces them all, it would make it easier than trying to order a dozen hoses individually. I also found one of the screws on the MAF to be loose, so I fixed that as well, hopefully that cures the the sometimes higher idle.
    Thanks,
    matt
    orange57's Avatar
    Nov 2010
    Phoenix, AZ
    34
    511
    Re: Northstar Coolant Hose Kit?
    i'm assuming a no based on the no responses. I'll have to see about ordering individually.
    malatu's Avatar
    malatu is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS 3.6 AWD
    Dec 2005
    1,005
    Couldn't you simply walk into a parts store and ask for all the hoses for a 2005 sts northstar?
    scott9001 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 sts N* 1965 coupe deville
    Aug 2011
    26
    364
    your best bet would probably go to a store and say i need upper and lower and all the little other ones that there might be get them all in pick them up at the same time and have at er!
    ts20rules is offline Cadillac Owners Member
    Automobile(s): STS
    Jun 2010
    1
    I went to Gates hose and downloaded the PDF of their Automotive Aftermarket Cat, look up my '06 STS, wrote down all the part numbers, ordering all from Amazon
  8. Remove Advertisements
