High Beam Sensor
Results 1 to 14 of 14
Cadillac STS Forum - 2005 through 2012 Discussion, High Beam Sensor in Past Cadillac Vehicle Discussion; Does anyone know how to change the settings for the Intelibeam? Or can it be changed? It seems as if ...
    teja2 is offline Cadillac Owners Member
    Mar 2004
    27
    High Beam Sensor
    Does anyone know how to change the settings for the Intelibeam? Or can it be changed? It seems as if the highbeams do not dim until the approaching car is on top of you.
    Dressel is offline Cadillac Owners Member
    Oct 2004
    Minnesota
    35
    Re: High Beam Sensor
    The high beams work very well either in dark straight roads or where there is alot of ambient light, as it does a good job sensing you are in the city. On curves, hills etc. they do seem to react a little closer than I would like them to also. In most cases I am pleased with them, it is just the few that tend to annoy me. To answer your question make sure your mirror is not blocked and your front windshield is clear, to my knowledge there is no distance or lite type adjustment.
    Vrocks's Avatar
    Vrocks is offline Cadillac Owners Connoisseur
    Automobile(s): CTS-V
    Feb 2004
    1,192
    teja2,
    I'll look into this tomorrow (actually it's already Tuesday). The system works well more often than not, however the few times when it waits too long can be annoying.
    Vrocks's Avatar
    Feb 2004
    1,192
    So far no luck on how to disable it other than doing some actual harware changes. I'll try to get my hands on the manual tomrrow.
    lev
    lev is offline Cadillac Owners Fanatic
    Jan 2003
    Planet Earth
    39
    407
    Quote Originally Posted by teja2
    This really depends on what car you have.
    I used to, million years ago, have 1983 Fleetwood Brougham. It had an auto-dim feature. I had to crank it to the most sensitive as otherwise it would just blink high-low beams all the time, annoying everybody.
    But when I got out on country roads with no source of light but my headlight, high beams would come on religiously and switch to low beams as soon as any sign of the light came on.
    Good luck.
    Mar 2004
    27
    Quote Originally Posted by lev
    Good luck.
    My mom had an 85 Fleetwood. It too had the sensitivity dial so you could change the hi/low beam distance. From looking at the STS, it doesn't seem like you have that ability. It is either on auto or manual. :disappoin
    stkviper is offline Cadillac Owners Member
    Dec 2004
    1
    Quote Originally Posted by Dressel
    Ok Here you go,
    Turning on and off your Intellibeam.
    Press and hold the on/off button on the inside rearview mirror for about 3sec. The indicator on the mirror will flash 3 time to let you know the Intellibeam has been turned off. Once the system has been turned off it will stay off untill you press the on/off button 1 time to turn back on.
    Playdrv4me's Avatar
    Playdrv4me is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1992 STS / 2005 MB G500 / 2003 STS / 2006 XLR-V
    Nov 2003
    TPA / STL / ICT / SAT
    11,694
    Wow, Caddies had smartbeam headlights WAAAY back then! That is a feature I thought for SURE was a recent invention. It seems like alot of the "new" innovations, are really bringing back older ones that werent ready for primetime back then... and maybe not quite yet.
    Blue Chip is offline Cadillac Owners Member
    Oct 2004
    Louisville KY
    80
    Besides having a switch on the mirror, Intellibeam also works only when your headlights are on "auto," rather than manual. I use Intellibeam all the time. It works very well. It's amazing how it immediately picks up the tail lights of a car even a good distance ahead of you so you don't annoy the driver with bright lights shining in his mirrors.
    caddydaddy's Avatar
    caddydaddy is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Escalade 6.0L 2WD, 2007 Jeep Grand Cherokee Limited CRD
    Jan 2003
    Gales Ferry, CT
    35
    3,717
    Quote Originally Posted by Playdrv4me
    Even older than that! My former '76 Fleetwood and Deville had auto dimming headlights. I'm pretty sure it first was available in 1964???
    sreno is offline Cadillac Owners Member
    Automobile(s): 2005 STS
    Feb 2003
    NW Chicago
    73
    16
    Quote Originally Posted by caddydaddy
    Would you believe it was in my '53 Oldsmobile? It was controlled by a unit about 5-6 inches tall that sat on the left side of the dashboard near the windshield.
    for_wheels is offline Cadillac Owners Member
    Dec 2004
    1
    I think that light detecting sensor for the Intelibeam system is on the front of the inside mirror. If the mirror isn’t on the windshield button all the way, the sensor might not see head lights in time. You might try loosening the screw that holds the mirror in place and make sure the mirror is on all the way.
    STSgirl's Avatar
    STSgirl is offline Cadillac Owners Member
    Automobile(s): 2005 STS (1SG) & 2007 Escalde EXT
    Aug 2004
    Michigan USA
    45
    Quote Originally Posted by sreno
    YES! My father-in-law had this feature on a Toronado back in the 60's.
  16. #14
    r0adawg is offline Cadillac Owners Member
    Jan 2005
    5
    does anyone know where this sensor is located on an 85 fleetwood brougham????
    thanks
  17. Remove Advertisements
