Double Din Navi installed (Avic x930bt) - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
Like Tree4Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Double Din Navi installed (Avic x930bt) in Past Cadillac Vehicle Discussion; Dead battery could cause loss all your seat preferences, mirror settings, sport or touring settings, etc. I would have had ...
  1. #16
    tomm's Avatar
    tomm is offline Cadillac Owners Connoisseur
    Automobile(s): 2014 Cadillac CTS VSport
    Feb 2005
    New Jersey
    67
    2,318
    Re: Double Din Navi installed (Avic x930bt)
    Dead battery could cause loss all your seat preferences, mirror settings, sport or touring settings, etc. I would have had them keep the original radio connected remotely.
    There are also better kits in my opinion and the installer should have given you all the options. I prefer the look of this one:
    Attachment 90086
  2. #17
    c32k05 is offline Cadillac Owners Member
    Automobile(s): STS
    Mar 2010
    29
    15
    Quote Originally Posted by cadillacboy22 View Post
    I am assuming either a new harness was made or It plugs right up with the adapter because it took the installer less than 20 minutes to remove my old head unit and install the factory back in. If your really interested in knowing I can pop the dash out and take some pictures.
    That would be great. I have been searching for a shop willing to do the work and no one wants to touch it without a harness.
    Quote Originally Posted by tomm View Post
    Attachment 90086
    Where did you find this kit? The only one I seem to find is the one the OP has.
  3. #18
    cadillacboy22's Avatar
    cadillacboy22 is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac STS V6
    Jul 2011
    27
    60
    I did see that kit but it seemed to be a lower quality then the metra. Its a Scosche cadillac sts double din. I would like to see someone try that out because if it looks better I can easily switch.
  5. #19
    Automobile(s): STS
    Mar 2010
    29
    15
    Any word on what harness they used to hook the aftermarket up? Is it the GMOS-13?
  6. #20
    Jul 2011
    27
    60
    Yes the harness I used was the GMOS-13 I found it the cheapest on sonicelectronix.com. Everything hooks up pretty simple with it.
  7. #21
    Midnight is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS 1SG
    Nov 2009
    Baltimore
    41
    309
    Like someone else said, it's great to know that aftermarket options exist, if your nav just decides to bite the dust which may not be too remote a possibility if you plan on owning this car for a long time.
    Our Nav from 2005 is also kinda showing its age in other ways - it's pretty slow, the touch screen (resistive I guess) requires a lot of mashing, the screen could be better, and there's the annoying lockout. I can't believe things haven't improved in the past 7 years.
    One thing I've considered is to custom mount a tablet in that area. I mean, they do just about everything you ever need and then some. Then if you ever needed to change settings, well the original is just behind it.
    Anyway, thanks to the OP for sharing.
  8. #22
    Lifer's Avatar
    Lifer is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 Cadillac Eldorado ETC
    Apr 2007
    Coppell, TX
    905
    One setting I repeatly use is in the Config screen. I press the Exit and the seat goes back and the steering wheel goes up, the same as when I turn the engine off and open the door. However I do this when the engine is running and I need to get out for some reason and do not want to turn the engine off. When I get back in I press the driver #1 setting (there are 2) and the seat and wheel returns. I would miss this feature with an after-market receiver.
  9. #23
    Budabear's Avatar
    Budabear is offline Cadillac Owners Fanatic
    Automobile(s): 2009 3.6 DI AWD Performance Package, 2003 Seville STS
    Dec 2003
    Yonkers, NY
    128
    I definitely like the look of the OP's installation, it's a different look but IMO its a good one. I have a top of the line Kenwood unit with Nav and it will go with me to my next car. I'm currently looking for an STS and I've only test driven one. The Bose system in it sounded terrible. I don't kow if the sound was correct or if there was something wrong. Definitely sounded like the later. I had the Bose system in my previous model Seville and it sounded fantastic.
  10. Remove Advertisements
