2007 STS Nav is Blank/Dead, need help - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Like Tree2Likes
Cadillac STS Forum - 2005 through 2012 Discussion, 2007 STS Nav is Blank/Dead, need help in Past Cadillac Vehicle Discussion; Just replaced my battery. The alarm went off when re-installing. Now my navigation screen is black. I think i had ...
  1. #16
    fredolan is offline Cadillac Owners Member
    Automobile(s): 2005 Cadillac STS4
    Oct 2006
    Detroit
    41
    Re: 2007 STS Nav is Blank/Dead, need help
    Now my navigation screen is black. I think i had this issue once before several years ago and it spontaneously
    came back on. Its been several hours and nothing.
    Any suggestions appreciated.
  2. #17
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Pull the Nav fuse for 10 minutes. Reinstall.
    If that doesn't work, do the reset procedure (disconnecting battery cables, touch them together & reinstall.)
  3. #18
    Angus Young's Avatar
    Angus Young is offline Cadillac Owners Fanatic
    Automobile(s): 2 Cadillac STS 1SG W/NAV
    Sep 2008
    Central Florida
    158
    Ive had luck pressing and holding the eject nav button for 6 seconds, the screen will move in and out, or try pressing the cd eject button or press them both and hold, mine usually comes back on after 3 or 4 eject's...
    dkozloski and dkozloski like this.
  5. #19
    chazglenn3's Avatar
    chazglenn3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 White Diamond STS N* 1SF RWD ACC/HUD
    Sep 2004
    Tacoma, WA
    54
    1,966
    Sorry to resurrect an old thread, but I changed my battery today and have the exact same problem...alarm went off and the nav screen is blank and all buttons unresponsive. I tried the eject buttons as mentioned above but no joy. The fuse under the seat on the passenger side is good...I swapped it for another and removed it as suggested. Is there a fuse on in the nav unit itself? Any other ideas?
  6. #20
    carter's_sts is offline Cadillac Owners Connoisseur
    Automobile(s): 06 STS-V & 06 STS 4 (sold 2016)
    Jun 2009
    2,030
    Try the reset procedure. Disconnect the battery again and touch the cables together for several seconds. Make sure the battery is charged before hooking it back up.
    The Navs seem to be sensitive to low voltage and can get in a non-working state until you disconnect the battery. The alarm sounding when you connect the battery is normal.
  7. #21
    chazglenn3's Avatar
    Sep 2004
    Tacoma, WA
    54
    1,966
    Well, I pulled the unit from the dash to disconnect and connect the plugs, and as I was pulling it out I heard the internal mechanisms come to life. All is well but I don't know what the deal was.
  8. Remove Advertisements
