Weak windscreen washer pump
Results 1 to 3 of 3
Cadillac STS Forum - 2005 through 2012 Discussion, Weak windscreen washer pump in Past Cadillac Vehicle Discussion; I figure it's behind the front fascia and under the reservoir, but can you remove/replace it without removing the nose? ...
    mckellyb is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 STS N*, 1SF, 144K mi.
    Apr 2011
    Fort Worth
    650
    I figure it's behind the front fascia and under the reservoir, but can you remove/replace it without removing the nose? My windscreen washers expel water with the force of a baby drooling.
    I should replace one of the burned out parking lamps in the headlight, anyway, but and LED is going in there so I don't have to do it again for a good while. Need to seal up the headlight housings, too, so it'll be a full-day thing, probably.
    Thanks!
    CTBB is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS N* 1SF
    Sep 2009
    Sunny California, Roseville
    67
    148
    Re: Weak windscreen washer pump
    Parts diagram shows it to be attached to the bottom of the washer fluid reservoir.
    http://www.trademotion.com/schematics/B/BC05360.gif
    I suspect you could access it from under the car with the undertray removed.
    Glenn
    Apr 2011
    Fort Worth
    650
    Thanks, makes perfect sense.
    I hope there aren't two, one for the headlights and another for the windscreen. Mercedes did that for at least a couple of decades.
