N* Losing coolant
Results 1 to 10 of 10
Cadillac STS Forum - 2005 through 2012 Discussion, N* Losing coolant in Past Cadillac Vehicle Discussion; I am getting a "coolant low" message about every 1-2 months. I see no evidence of leaks on the engine ...
    GREGB1954 is offline Cadillac Owners Member
    Automobile(s): '06 STS N* 1SG Pkg, blk/blk
    Nov 2010
    Indy
    56
    N* Losing coolant
    I am getting a "coolant low" message about every 1-2 months. I see no evidence of leaks on the engine or under the car.
    Any ideas?
    2006 STS N*
    02603sec's Avatar
    02603sec is offline Cadillac Owners Fanatic
    Automobile(s): STS 1SF Black V8 2006
    Sep 2008
    Bucks County PA
    57
    456
    Re: N* Losing coolant
    Hi, That's leaking to slow to notice anything on the ground. You may want to run your finger under the water pump seal/bearing . Bet there is coolant there.
    B1n2fra's Avatar
    B1n2fra is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 1SG STS v8 awd
    Nov 2011
    Chicago
    36
    502
    Mines is leaking also but I see big puddles under my car sometimes or I smell the sweet smell of coolant burning off. Never get a low coolant message or never run hot. It only leaks when I add into the resevoir. I don't understand. During the winter I have no heat unless I add coolant and It slowly leaks out. At times it leaks massively.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Members haven't reported any head gasket issues like the pre-2005 STS but water pump issues aren't uncommon. Earlier model years are getting to the age that AR owners consider replacing all hoses. I bet they are OK.
    If you garage the car and notice that sickly sweet smell, I'd bet on a leaky pump. I had one that left a puddle at about the firewall.
    bbshriver's Avatar
    bbshriver is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 STS V8
    Mar 2008
    Allentown, PA
    31
    574
    Mine got a new water pump at ~50kmi for this reason... I never noticed fluid on the ground, or smelled antifreeze, but every so often the light would come on and I'd check the reservoir and it would be low. CPO warranty ftw... Dealer claimed it was a $700 fix.
    Nov 2010
    Indy
    56
    I'll take a closer look at the water pump. My Pontiac 3800 pump lasted for 205,000 miles. I would like to believe the GM had figured out how to build a long lasting pump.
    chazglenn3's Avatar
    chazglenn3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 White Diamond STS N* 1SF RWD ACC/HUD
    Sep 2004
    Tacoma, WA
    54
    1,947
    Just had my water pump replaced at 103K miles. They also had to replace the crossover gaskets. Still leaked when I got it back...turned out to be the thermostat housing o-ring. Nice to have a new pump too, however. This was fixed under my extended warranty.
    Nov 2010
    Indy
    56
    Thx for the tips. I'll look at the thermostat housing as well.
    Midnight is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS 1SG
    Nov 2009
    Baltimore
    41
    308
    I got a new water pump and thermo housing gasket @ about 65k or something. Fixed my issue. Dealer did a pressure check - you could see the evidence for the thermostat housing leak, but the WP was a surprise. The level in the reservoir hasn't moved since then thankfully Mine smelled pretty strongly of anti-freeze at the time I had it repaired, but the leak was like adding a pint a week or something (driving ~350 mi/week).
    B1n2fra's Avatar
    Nov 2011
    Chicago
    36
    502
    Found the culprit. Same as others. The dang water pump. No other leaks were detected when I performed a pressure check.
  13. Remove Advertisements
