Can a Fram Air Filter cause P0171/P0174 codes
Results 1 to 11 of 11
Like Tree2Likes
  • 2 Post By dkozloski
  • 1 Post By EChas3
Cadillac STS Forum - 2005 through 2012 Discussion, Can a Fram Air Filter cause P0171/P0174 codes in Past Cadillac Vehicle Discussion; I have been having problems with the check engine light coming on, and it giving me the P1071 / P0174 ...
    Zman1001 is offline Cadillac Owners Member
    Jun 2006
    23
    I have been having problems with the check engine light coming on, and it giving me the P1071 / P0174 codes that the car is running lean.
    I know that one of the things is that an oiled air filter can cause an oil buildup on the Mass Air Flow sensor.
    Is the Fram air filter oiled? Could the Fram air filter be causing this problem?
    Thanks
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,314
    Re: Can a Fram Air Filter cause P0171/P0174 codes
    Check to make sure you reconnected the PCV line when you installed the filter.
    Don't mess with Binky Bear!
    chazglenn3's Avatar
    chazglenn3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 White Diamond STS N* 1SF RWD ACC/HUD
    Sep 2004
    Tacoma, WA
    54
    1,966
    Fram air filters are not oiled.
    Jun 2006
    23
    Thanks for the responses. I did not think that the FRAM was oiled, but since that is one of the possible symptoms is an oiled air filter causing buildup on the MAF sensor. Dealing with a 2008 STS
    I am officially above my head now. I never knew that changing an air filter would be so difficult. When I changed the air filter, I unscrewed the bolts, took out the old air filter (which looked identical to the new one, but not sure what brand), put in new one, then put screws back in. I did not see any other connections, and not sure exactly what PCV line is:
    A little more background.
    I have had the check engine light come on a few times, but would go out again. Just when I was going to take it to the dealer, we had an ignition coil go bad. Got replaced. The three days later the light came back on. Had the vacuum hose replaced. light came back on next day after getting back.
    It is now with them again and they have recently replaced the MAF sensor, but their tests are still coming up that it is running lean.
    One of the things on the checklist is that some aftermarket air filters could cause this problem. Not sure the air filter is the problem as some time had passed, but wanted to see if anyone else had run into this problem
    That is why I was asking the question.
    Thanks again.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,314
    The big rubber/plastic hose between the air filter and the throttle body has a connection about midway that goes to the PCV connection on the left valve cover. It's easy to overlook but a blind man could reconnect it. If left loose it will cause several different codes.
    Jesda and Jesda like this.
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,870
    If you purchased a Fram ToughGard filter, it is oiled. Most people don't buy these ones. Depsite this, I agree with koz. This sure sounds like there is unmetered air getting in the system. Check all the connections from the air box back, including any vacuum lines.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    N*? Could this be another set of loose intake manifold bolts?
    Tom's Caddy likes this.
    Jun 2006
    23
    Thanks everyone. It was just the Fram Extra Guard filter.
    I will let everyone know what it is. My car has been at the dealer for over one week now trying to figure this latest one out. The reason I posted this question is because they called me asking about the filter. Again, their check list that they are going down says that after market air filters could cause the "lean" codes, and they called me.
    I will let you know what finally comes back, since they already replaced the MAF sensor and it is still showing it running lean.
    REALTORBENJAMIN's Avatar
    REALTORBENJAMIN is offline Cadillac Owners Fanatic
    Dec 2012
    275
    Quote Originally Posted by Zman1001 View Post
    Ever get sorted? Thinking of ditching my KnN filter and putting a regular one in to see if that increases my MPG. I am averaging up to 19L/100km right now = 12 MPG?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,173
    ALL pleated paper air filters have some tiny amount of "oil" in them. It's part of the paper forming/pleating process. Smell one. NONE of the commercially available pleated paper air filters has enough "oil" in it to damage anything.
    K&N filters, if the wash and oil type, are typically abused by the owners because, as with all hype and snake oil, if a little is good, more must be better. We decode and replace quite a few MAF sensors of different types due to K&N zealots screwing things up with that damned "filter oil". (Marvel Mystery Oil - a few drops - works just fine. Let it spread through the media for 3 days.)
    For any vehicle with a divorced MAF and air ducting clamped to the filter box/throttlebody, any clamp left loose, and sensor or PCV line left open/unplugged, any rip in the intake ducting causes lean mixture codes.
    For example, in this picture, any air leak at or after the MAF WILL set lean codes. Ask me how I know.
    Actually, FRAM makes damn good air filters. Their oil filters, however, leave something to be desired. I happen to be partial to WIX filters.
    Midnight is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS 1SG
    Nov 2009
    Baltimore
    41
    309
    My 2005 STS N* had an issue with the MAF sensor, although I'm sorry I don't remember the exact codes, it's been a couple years.
    It was an intermittent problem and I actually bought a new MAF sensor, which is surprisingly not too expensive, thinking that would solve it, but it didn't. From there, I hooked my code reader which has some live output (one of which is the MAF sensor value). With the car running I was able to reproduce the problem when wiggling the MAF sensor harness' wires.
    On inspection it looked like the wire had a spiral cut in the insulation and the wire itself, at a similar pitch to the wrapped "tape" that bundles up and protects the wires. I don't know if this taping is done at the factory by a robot or by hand, but my theory is somehow it was done wrong and weakened the wire and over the years it fatigued and separated internally.
    Anyway, I just cut and spliced and re-taped and no more problems.
    So something to definitely check especially if this was some kind of manufacturing problem.
    good luck.
  14. Remove Advertisements
