Low Beam headlights out
Results 1 to 8 of 8
Cadillac STS Forum - 2005 through 2012 Discussion, Low Beam headlights out in Past Cadillac Vehicle Discussion; today my headlights decided to quit working, just the low beams. The brights and fog lights work just fine. I ...
    05_STS is offline Cadillac Owners Member
    Automobile(s): 2005 STS
    Jan 2011
    Findlay, OH
    28
    48
    I replaced all of the bulbs less than 6 months ago so I don't suspect bulbs, especially since they both stopped working at the same time (today). I have checked both headlight fuses and both are good, I can hear the headlamp relay click when I move from parking light to headlights with the switch so I assume the relay may be okay.
    I'm clueless what to check next, it's not like the bulbs are easy to check too...
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Low Beam headlights out
    Ground wire.
    Is there a fuse? Fusable links are gone, aren't they?
    Jan 2011
    Findlay, OH
    28
    48
    There are two fuses for the low beam headlamps, one for each side.
    Also, from what I've read and seeing in the diagrams, each headlamp is grounded separately and the ground is shared with the fog lights, which are working.
    Looks like I'll be pulling the front end apart to check the bulbs, this sucks...
    chazglenn3's Avatar
    chazglenn3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 White Diamond STS N* 1SF RWD ACC/HUD
    Sep 2004
    Tacoma, WA
    54
    1,947
    Make sure you use gloves or something when/if you replace the bulbs this time. If you touched them with your bare hands, you left oil on the bulb that then causes a hot spot and the bulbs overheat and burn out prematurely.
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    ^^^^ Ever since the end of sealed beams!
    Jan 2011
    Findlay, OH
    28
    48
    So I'm getting pretty good at pulling off the front bumper, both bulbs were burned out. What a coincidence, both were brand new less than 6 months ago and were nice Sylvania SilverStars and they burned out at the same exact time.
    So I went with Sylvania SilverStar Ultra bulbs this time, $23 a pop...
    I never touch bulbs with my bare hands, any idea what could have caused them both to burn out at once without blowing a fuse first?
    UNKUT's Avatar
    UNKUT is offline Cadillac Owners Fanatic
    Automobile(s): 2000 DTS / 2005 STS
    May 2009
    Ohio
    36
    380
    Quote Originally Posted by 05_STS View Post
    That sounds like WAY more then a coincidence to me! And its good to hear your good at removing the bumper lol! You should start posting tutorials with as much knowledge as your compiling!
    chazglenn3's Avatar
    Sep 2004
    Tacoma, WA
    54
    1,947
    The SilverStar and SilverStar Ultra bulbs produce more light because they are over driven and that reduces their useful life span. That being said it seems like 6 months is still too short. I was replacing those in my wife's Pacifica once a year so I switched to GE NightHawk bulbs...they are longer lasting as they are not as aggressively over driven. Do you leave your Rainsense wipers on? That would keep the headlights on all the time...
  11. Remove Advertisements
