Water in the Headlights - Page 3
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 49
Like Tree2Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Water in the Headlights in Past Cadillac Vehicle Discussion; Originally Posted by dkozloski It's not hot enough to melt any seals. I'd open both covers. Moisture is fine. WATER ...
  1. #31
    maiahsdad's Avatar
    maiahsdad is offline Cadillac Owners Fanatic
    Automobile(s): 05 STS AWD 1SG
    Apr 2009
    Fishers, Indiana, USA
    484
    Quote Originally Posted by dkozloski
    Moisture is fine. WATER is terrible.
    dkozloski and dkozloski like this.
  2. #32
    maiahsdad's Avatar
    Apr 2009
    484
    Took drill with 1/16 bit and drilled tiny hole at bottom, lowest point of the fixture. I can hardly see the hole. But a small trickle formed. Should B empty in a few hours.
  3. #33
    MARSTS is offline Cadillac Owners Member
    Automobile(s): 2012 CTS4
    Oct 2011
    23
    Re: Water in the Headlights
    I have had experieince with this problem with a simple correction (solution). Do not drill any additional holes into the housing. This is a common problem with these headlamp assemblies. They leak from the seal around the perimeter of the housing. If and when you can remove the assemblies from the car, just run a bead of silicone around the seal that mates the black rear part of the assembly to the clear plastic that is your lens. I replaced the halogens for HIDs and while I had everything out, I did this. In addition, I replaced the other two bulbs, replaced the access panels and siliconed them to the assembly in case they decided to leak. Everything is now sealed and working perfectly. I don't believe I will have to revisit this with the HIDs installed. I still get the fine condensation once in a while, but once the temperature changes this quickly goes away - this is normal. Good luck!
  5. #34
    02603sec's Avatar
    02603sec is offline Cadillac Owners Fanatic
    Automobile(s): STS 1SF Black V8 2006
    Sep 2008
    Bucks County PA
    57
    456
    You can pop the front facia in a few minutes. Expose the fixtures clean them reseal them reinstall
  6. #35
    maiahsdad's Avatar
    Apr 2009
    484
    Quote Originally Posted by 02603sec
    The dealer says u have to remove the entire front bumper that requires an hour of labor.
  7. #36
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    There are quite a few threads offering tips and tricks for handling the bumper facia. The dealer will charge you the book number for labor hours.
  8. #37
    malatu's Avatar
    malatu is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS 3.6 AWD
    Dec 2005
    1,005
    And the fact is, they may not even take it completely off. I watched my mechanic replace the headlight assembly with out removing the tire or the entire bumper fascia. It was tight but he got it done.
  9. #38
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    I'd rather do it (or have it done) by the book. What if they damage my car and I don't notice?
  10. #39
    chazglenn3's Avatar
    chazglenn3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 White Diamond STS N* 1SF RWD ACC/HUD
    Sep 2004
    Tacoma, WA
    54
    1,947
    I can get my fascia off without removing either wheel in about 15 minutes. I dont remove the headlight washers so it isn't completely off the car but enough to access the headlamp assemblies.
  11. #40
    malatu's Avatar
    Dec 2005
    1,005
    Quote Originally Posted by EChas3 View Post
    I agree, but my point was if you can't stand there and watch them, how will you ever know if they took it off or not?
  12. #41
    maiahsdad's Avatar
    Apr 2009
    484
    I find that although the dealer said that all was sealed appropriately, I get heavy condensation following running the car through Mike's Drive-Thru Car Wash.
  13. #42
    BaTu is offline Cadillac Owners Enthusiast
    Automobile(s): '05 STS4
    May 2008
    668
    Quote Originally Posted by maiahsdad View Post
    Again, Because,,, the seal has failed between the body and the lens (as it has for Many of us before) and is easily cured by removing the headlight and running a bead of silicone around that seal.
    (or just keep "moaning" about it if you'd rather.....)
  14. #43
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    Quote Originally Posted by BaTu View Post
    Or avoid Mike's Drive-Thru Car Wash.
  15. #44
    maiahsdad's Avatar
    Apr 2009
    484
    LOL! I'm moaning because the tech at the dealer who had the facia off looking at it with me said the effort was futile. He refused to do it for me (I have no tools). Said it would prevent any tech from getting inside again. I let him read these posts. I wanted to be sure I was asking him to do the right thing.
    And I don't see how the drive thrus can cause that. But now I continue to moan. But not on this forum.
  16. #45
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    I use a drive-thru reularly with no such issues. Take your car to a shop that wants to fix it.
  17. Remove Advertisements
