2005 STS tail light - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
Cadillac STS Forum - 2005 through 2012 Discussion, 2005 STS tail light in Past Cadillac Vehicle Discussion; Can't you take the right taillight out and connect it to the connector for the left one? Then if it ...
  1. #16
    Cadjiek is offline Cadillac Owners Fanatic
    Automobile(s): 2015 xts Premium fwd 2009 CTS AWD
    Apr 2009
    468
    Re: 2005 STS tail light
    Can't you take the right taillight out and connect it to the connector for the left one? Then if it still doesn't work it has to be be the lamp assembly.
  2. #17
    KRSTS Guest
    Great diagnostic idea
  3. #18
    perrior is offline Cadillac Owners Member
    Automobile(s): 2005 sts
    May 2013
    72
    5
    I have the same problem and I switched the drivers side with the passenger side and the brake lite still doesn't work. So I'm thinking that
    there is something wrong with the pc board inside. Does anyone know how to remove the tailight lens so I can get at the pcb and check it out and does anyone have a schematic.
    thanks in advance
    Bob
  5. #19
    sub613's Avatar
    sub613 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 STS 1SF N* RWD NAV F55
    Mar 2009
    NC for Now, Florida SOON
    704
    Not sure what I meant, when I wrote the above, it was a year ago....
    I think I meant when you put the emergency flashers ON, do they both blink...
    Sorry for the confusion.
    Would be interested in anyone removing the Lens to work on the PCB.
    I have ONE led out on the passenger side. thanks.
    Happy Motoring..
  6. #20
    caddieburg is offline Cadillac Owners Member
    Automobile(s): None
    Feb 2014
    1
    Has anyone figured out any other fix for this problem other than spending the $150-200 to replace the tail light assembly?
    caddieburg, Your account is now activated. Please update your profile to reflect your correct age, Cadillac driven, location and time zone (Do you really live in London ?) Use the settings, edit profile tab. Welcome to CF.
  7. #21
    May 2013
    72
    5
    I read something about putting the assembly in a oven and then try to pry open the len... I didn't want to try that as there was no mention on how to reseal it so I just bit the bullet and ordered one from the local chevy dealer at a cost of $400 and some odd cents... What a rip.. I still have the old assembly in my trunk..
  8. #22
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    I think there's a link in the 'sticky' thread. I know some member posted a nice step-by-step write-up.
  9. #23
    B1n2fra's Avatar
    B1n2fra is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 1SG STS v8 awd
    Nov 2011
    Chicago
    36
    502
    Which year's have the darker tail light lens and which ones have the lighter ones. I bought my car and found out it had a previous rear end accident and both of the taillights don't really match, and it bothers me to have one light one and one darker one. I wanted to buy a replacement but needed to know what year assembly to purchase.
  10. #24
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Quote Originally Posted by B1n2fra
    05-07
  11. #25
    jsg1402 is offline Cadillac Owners Member
    Automobile(s): 2005 STS
    Sep 2014
    Bucks County PA
    33
    Hate to bring up an old thread, just looking for clarification. My right rear brake light doesn't work, but the tail light and turn signal works. In reading through the thread the left and right brake LEDs are on the same fuse which is located in the fuse block underneath the back seat on the passenger side. First step is to check the fuse and replace, if a new fuse doesn't solve the problem pull the connector from the tail light assembly and check for any type of corrosion, if connector is OK then check voltage as mentioned previously. If all three are OK then its time to replace the tail light assembly. I know gmpartsdirect is probably the cheapest place to get the part with a one year warranty. I guess I could call around to some auto salvage yards to see if they have any, of course I'd have to make sure they have tested the assembly to see if it all works properly. I hope I haven't misread this thread.
  12. #26
    kiewee3 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS N*
    Sep 2012
    Iowa
    20
    125
    Quote Originally Posted by jsg1402 View Post
    This happened to me so I had to replace the Drivers side. Now the passenger side is going bad... Just take out both and test the bad on the good side and the good on the bad side. A little A/B testing will provide you with your answer
  13. #27
    sub613's Avatar
    Mar 2009
    704
    Deleted, Duplicate post
  14. Remove Advertisements
