Valve Cover Gasket Change $545.00 isn't that too much for 2006 STS (V-8)
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Like Tree1Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Valve Cover Gasket Change $545.00 isn't that too much for 2006 STS (V-8) in Past Cadillac Vehicle Discussion; Just wanted to know if y'all thought $545.00 was too much for replacing Valve Cover Gasket for my 2006 Cadillac ...
    cruzajc1's Avatar
    cruzajc1 is offline Cadillac Owners Enthusiast
    Apr 2004
    500
    Just wanted to know if y'all thought $545.00 was too much for replacing Valve Cover Gasket for my 2006 Cadillac STS (V-8) Northstar?
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,263
    Re: Valve Cover Gasket Change $545.00 isn't that too much for 2006 STS (V-8)
    With the cam adjusters and such to deal with it doesn't sound that bad.
    Don't mess with Binky Bear!
    Jesda's Avatar
    Jesda is offline Super Moderator
    Automobile(s): 2002 Seville STS F55, 2006 Mazda Miata
    Sep 2003
    DETROIT
    35
    22,380
    Dealer? Sounds fair to me.
    Greg00coupe is offline Cadillac Owners Enthusiast
    Automobile(s): 05 STS
    Jan 2005
    Canton, Oh
    64
    512
    Go to NAPA ask them to recommend a good independent mechanic. Take it to them to compare.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Quote Originally Posted by Greg00coupe View Post
    More independants claim to know Cadillacs than actually do.
    wake likes this.
    malatu's Avatar
    malatu is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS 3.6 AWD
    Dec 2005
    1,005
    Most independent I've dealt with just want to perform as many brake jobs and other basic services they can. Can you blame them? I've dealt with some other independents that advertize services above and beyond.....turned out to be nothing but disappointment. I'm not suggesting there aren't great independents out there.... I just haven't found them.
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    29
    4,561
    Quote Originally Posted by Jesda View Post
    +1.. It's a multi-hour job, and I'm sure the acutal OEM gaskets costs $50 or so. In this case, I'm sure a Dealer is going to do just as good a job as an Indy will if you go to a dealer with any kind of northstar experience.
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,826
    GM's labour time to do both sides is only 3.2 hours, + .1 - .3 for cleaning of parts on cars > 30,000 miles. Depending on the cost of parts, it sounds a little steep. Of course a competent technician can do it less time (it's quite straight forward), but they'll never charge you less than the book time anyway. One of my big pet peeves about the auto repair industry.
    CTBB is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS N* 1SF
    Sep 2009
    Sunny California, Roseville
    67
    148
    Quote Originally Posted by ddalder View Post
    +1234 Definitely a scam on the consumer.
    Glenn
    Jan 2005
    Canton, Oh
    64
    512
    That's why I suggest going to NAPA. They supply quality parts to all the independents and know who is honest and fair. My independent mechanic is an ex tech from the local Cadi dealer. He is honest and fair priced. You want to believe that only Cadillac can fix a Cadillac knock yourself out. Same commentators believe you got to have a warranty and these cars are very unique to fix. It's all in your attitude and your willingness to do a little research.
    Jesda's Avatar
    Sep 2003
    DETROIT
    35
    22,380
    I'm also a fan of Napa. Wish we had some of their stores here.
    ddalder's Avatar
    Aug 2008
    Canada
    2,826
    It depends on the job. The task in question here is a good example (along with many other "general" repairs) that I might use an independent shop for. There are many other repairs I wouldn't even consider asking a non-dealer about. Most independants are simply not equipped, or have the technical resources at hand to tackle some problems.
    cruzajc1's Avatar
    Apr 2004
    500
    Thanks so far for the information, what adjustment has to be done to the cam by changing the valve cover gasket?
  16. #14
    TimmyC is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-V and 2007 STS-V The Murdalac
    Feb 2009
    1/2 hr S of Grand Rapids, MI
    37
    1,897
    Quote Originally Posted by cruzajc1 View Post
    None. I can get the left side valve cover off my car in 15 minutes, no joke. I did it last week to change the baffling inside. There is no need to touch any of the cam hardware. The right side is tighter so it would probably take me longer, but nowhere near $545 worth.
  17. #15
    ddalder's Avatar
    Aug 2008
    Canada
    2,826
    Agreed. The cam steppers change the shape at the end of the head a little but they mount directly to the head. The cover is also shaped accordingly but has no other involvement with the workings. Most of the work, as mentioned, is with access. As with most book times, 3.2 hours is generous.
  18. Remove Advertisements
