Valve Cover Gasket Change $545.00 isn't that too much for 2006 STS (V-8) - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Like Tree1Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Valve Cover Gasket Change $545.00 isn't that too much for 2006 STS (V-8) in Past Cadillac Vehicle Discussion; Does changing the Valve Cover Gasket on the Passenger Side of 4.6l V8 require lifting the motor. I've replaced twice. ...
  1. #16
    toddkellogg is offline Cadillac Owners Member
    Automobile(s): 2004 srx v8
    Jun 2012
    17
    Re: Valve Cover Gasket Change $545.00 isn't that too much for 2006 STS (V-8)
    Does changing the Valve Cover Gasket on the Passenger Side of 4.6l V8 require lifting the motor. I've replaced twice. Still leaks....dammit! Put sealant on the second time (against the gasket manuf. instructions). Its holding on the other side (I think).
    Took it to my local chevy dealer(yes, chevy, they are really good) and they said the Northstar valve covers are Notorious for Warping!!! Imgine my horror after hearing this. NO GASKET OR GLUE WILL COMPENSATE FOR A BENT VALVE COVER! Dammit again, the time and energy I put into replacing that gasket and I hear that!
    Had to loosen one bolt from UNDER THE CAR.
    Anyone else having this/these issues? OIL SMELL IS ANNOYING W/ AC ON AND WINDOWS UP.
  2. #17
    HelpMySTS is offline Cadillac Owners Member
    Automobile(s): 2005 STS V8
    Mar 2014
    26
    1
    I am wanting to k ow the same thing. How do I reach the valve cover bolts on the passenger side? Something is blocking the way. My guess is that it's a wire harness shield of some kind but how do I get around it?
  3. Remove Advertisements
