05 STS V8 Northstar oil leaks - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Cadillac STS Forum - 2005 through 2012 Discussion, 05 STS V8 Northstar oil leaks in Past Cadillac Vehicle Discussion; update: I just got mines back from the dealer last week for an oil leak . They replaced (oil manifold ...
  1. #16
    caddyfat2 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS4 1SG w/ HUD-ACC
    Jul 2010
    TAMPA, FLORIDA
    462
    Re: 05 sts v8 northstar oil leaks
    update:
    I just got mines back from the dealer last week for an oil leak . They replaced (oil manifold lower crankcase seals). $2900.With only 74k miles.
  2. #17
    willysmooo is offline Cadillac Owners Member
    Automobile(s): 2007 STS V-8 AWD ISG, Tuscany seats, per. cooling etc
    Mar 2012
    42
    65
    Dont ask me why,but I was thinking about your CAM issue.....and I always look for TSB's about twice a year. There are 2 TSB's for the CAM sensors/and or CAM actuators in the STS....some from movement or inproper seals. If you google TSB and go in the NHSTB(or whatever the heck it is) you may just be ablke to get this taken care of.
  3. #18
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    Mines in the shop again for this. Oil fouling out the cam sensors due to bad actuator seals.
  5. #19
    dawgy2219 is offline Cadillac Owners Member
    Automobile(s): sts
    Jun 2010
    18
    Any chance it is being covered by Gm for a recall since there is a Tsb for the cam sensor?
  6. #20
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,212
    Recalls are for safety items. PITA items out of warranty are on the owner.
    Don't mess with Binky Bear!
  7. #21
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,857
    Re: 05 STS V8 Northstar oil leaks
    Looks like the thread died over 2 years ago.
    Never did hear of a recall.
  8. #22
    Automobile(s): sts
    Jun 2010
    18
    I found out that my camshaft position actuator oil control valves need replacing be cause they are leaking through the electrical connection at the front of the engine. Do I need to replace the actuators themselves (the circular actuator with teeth that need to be properly aligned) or can I get away with just replacing the oil control valve?
  9. #23
    2manyhotrods's Avatar
    2manyhotrods is offline Cadillac Owners Fanatic
    Automobile(s): 1999 Eldorado ETC coupe.
    Jun 2013
    Massachusetts
    438
    My Northstar engine with 125,000 miles pukes oil out until it drops 1/2 to maybe 1 quart down. Appears to leak from the crankshaft seal and the separator plate.
    I put cardboard under it when parked inside my garage.
    It's a build result from the Roger Smith era.
    That's the reason my normal daily driver as well my wife's car are Toyota products.
  10. #24
    Automobile(s): sts
    Jun 2010
    18
    Is it safe to drive with those leaks? Can I do more damage or just keep up on oil levels?
  11. #25
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Keep the oil at the proper levels and it'll be fine.
  12. #26
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    The redesign for the XLR/SRX/STS fixed the old N* ills.
  13. #27
    1BadCadSTS's Avatar
    Nov 2010
    30
    4,224
    Quote Originally Posted by EChas3
    Aka the LH2 and LC3 vs the old LD9 and L37
  14. #28
    DG2's Avatar
    DG2
    DG2 is offline Cadillac Owners Connoisseur
    Jul 2004
    1,703
    My Northstar seeps some oil at the seams and I add two quarts every 2500 miles. I never did anything about it and the engine is all original and at 203,000 miles runs great.
  15. Remove Advertisements
