JL9 to JE5 swap a NO GO!! UGHHH
Closed Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Like Tree3Likes
Cadillac STS Forum - 2005 through 2012 Discussion, JL9 to JE5 swap a NO GO!! UGHHH in Past Cadillac Vehicle Discussion; I just received my JE5 rotors and brake pads that I purchased online. It seems that no one on here ...
    1_bad_cad's Avatar
    1_bad_cad is offline Cadillac Owners Member
    Automobile(s): STS
    Jan 2011
    64
    I just received my JE5 rotors and brake pads that I purchased online. It seems that no one on here has actually done the swap or I just couldn't find it but I read on here that it was as simple as just replacing the rotors and brake pads. I just tried installing and it seems as though the bracket on the JL9 system that the caliper bolts into is not large enough to fit over the JE5 rotors. The caliper itself looks okay but its just that bracket. Does anyone know if i can simply replace that bracket with the JE5 one or do I just have to stick with the JL9 setup? Thanks in advance
    Quick reply to this message Reply
    AnderbrA is offline Cadillac Owners Member
    Automobile(s): 2007 Cadillac STS V8
    May 2008
    Sioux Falls, SD
    95
    Re: JL9 to JE5 swap a NO GO!! UGHHH
    The rotors are larger, you will need the JE5 caliper. It appears that the knuckle that it mounts to is the same part number. It looks like the rear may be the same tho.
    May 2008
    Sioux Falls, SD
    95
    Part numbers for the JE5 calipers: Looks like you can get them for a touch over $100 apiece.
    89027066
    89027067
    1_bad_cad's Avatar
    Automobile(s): STS
    Jan 2011
    64
    The caliper doesn't come with the bracket and I would need both the caliper and bracket to do the swap and that's over $300 for just the front
    sub613's Avatar
    sub613 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 STS 1SF N* RWD NAV F55
    Mar 2009
    NC for Now, Florida SOON
    704
    CoolRe: JL9 to JE5 swap a NO GO!! UGHHH
    What are you trying to do ?There are a lot of experts here to help you.
    I have a Standard STS, and the Front brakes are two piston, Delco has a 4 piston
    caliper available for this installation, If Needed, I can give you the Delco numbers.
    Have fun, keep us in tune what you are doing,so we can also learn. Thanks
    AnderbrA above looks like the numbers I have !
    1_bad_cad's Avatar
    Automobile(s): STS
    Jan 2011
    64
    Quote Originally Posted by Subsailor613 View Post
    I was trying to upgrade my standard JL9 brakes to JE5 drilled/slotted rotors and pads. I ordered a set of 4 online with brake pads and I just received them today. I went to install them and the caliper bracket that holds the caliper in place for the JL9 does not fit over the JE5 rotors. The stealership wants about $95 a piece for the JE5 brackets but I was told that I would also have to change the calipers too and they are a little over $100 each. I saw the brackets online for about $55 each but I dont want to spend another $600 doing this upgrade. I unfortunately had to pay $70 in shipping and restocking fees for this failed upgrade. Im a little disappointed that I have to stick with the JL9 setup. Thanks for the help guys
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    why would you even attempt this, anyone with any set of brake sense should know they couldnt do this. hell if i get J56 (brembo) pads and rotors I must be able to do a full V spec brake upgrade right? really common now... The improved braking of the JE5 over the JL9 is the larger rotor which pushs the caliper out further. How do you think they achieved that? Clearly with a larger abutment bracket which sets the even larger JE5 caliper out further to clear that bigger JE5 rotor....
    sub613's Avatar
    Mar 2009
    704
    I have put drilled and slotted rotors on my standard brakes,
    with what was standard rotors, and used the standard calipers.
    BaTu is offline Cadillac Owners Enthusiast
    Automobile(s): '05 STS4
    May 2008
    668
    Quote Originally Posted by 1_bad_cad View Post
    Dude, you're obviously in over-your-head here, take your car to a Brake Shop before you Kill Somebody!
    May 2008
    Sioux Falls, SD
    95
    It appears that the knuckle is the same for both. You will need the entire brake setup to make this work. Rotor and all caliper hardware. Your best bet is to find a donor vehicle from a junkyard IMO or return your purchase and get the JL9 setup.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    IMHO, the JL9 feels inadequate after getting acustomed to driving an STS with the JE5.
    I ought to test-drive a STS-V. I wouldn't want to give up ACC, but it would be fun!
    1_bad_cad's Avatar
    Automobile(s): STS
    Jan 2011
    64
    Quote Originally Posted by 1BadCadSTS View Post
    First of all, instead of being a forum prick, why don't you just offer some helpful advice? There are so many people like you on this forum that do nothing but negatively criticize what others are doing or trying to do with their cars. Obviously things are sometimes going to be trial and error for some people but its the fact that people are trying to modify or customize their cars in their own ways because they don't make many mods for these cars. Secondly, I attempted this because obviously I wanted better braking performance. I bought a couple of parts for the swap but obviously just didn't pick up everything that I needed. There isn't a step by step guide to doing this swap so maybe you should make one since you know so much about it. Sorry if I don't see the harm in that and understand why you need to be such a smartass. But its okay because its not going to ruin my day and I know just how tough everyone can be over a keyboard. But to the others with actual helpful comments and remarks, I appreciate it and thank you.
    1_bad_cad's Avatar
    Automobile(s): STS
    Jan 2011
    64
    I repurchased drilled and slotted jl9 rotors. Did you feel a difference in the standard and new drilled/slotted? Thanks
  16. #14
    1_bad_cad's Avatar
    Automobile(s): STS
    Jan 2011
    64
    Quote Originally Posted by BaTu View Post
    Well with the right help, it can be done personally. Its not brain surgery but like I said before its trial and error and when things don't fit then you buy the parts that do or you go back to stock. Thanks for your reply though
  17. #15
    1_bad_cad's Avatar
    Automobile(s): STS
    Jan 2011
    64
    Quote Originally Posted by EChas3 View Post
    I haven't driven an STS with the JE5 but I hear from everyone that has that its a total transformation and no one ever wants to go back down to JL9. I am considering selling my car in the future and test driving an STS-V. If that goes as planned, I wouldn't need any more brake swaps lol
  18. Remove Advertisements
Closed Thread
