headlight question
Results 1 to 9 of 9
Like Tree3Likes
  • 2 Post By torogt
  • 2 Post By hellamint
  • 2 Post By galaxy1000
Cadillac STS Forum - 2005 through 2012 Discussion, headlight question in Past Cadillac Vehicle Discussion; Does anyone know if the headlamp assembly from the non-hid light can be converted to hid or is there a ...
    torogt is offline Cadillac Owners Member
    Automobile(s): 2006 STS 4 V8 White Diamond Pearl 1SG
    Nov 2010
    53
    59
    headlight question
    Does anyone know if the headlamp assembly from the non-hid light can be converted to hid or is there a difference in the housing, I notice a lot of non hid housings for sale fairly cheap compared to hids so if they were the same I thought about buying one and then putting my hid components on it???
    caddyfat2 and caddyfat2 like this.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: headlight question
    There's a thread describing the conversion and a lot of posts describing the shortcomings. Try some searches.
    hellamint is offline Cadillac Owners Member
    Automobile(s): 2007 STS4
    Aug 2010
    13
    I just replaced my halogen low beams (h11 bulb) with HID's. 100% night and day difference. A pain to remove bumber and install, but well worth it!
    Frikiton and Frikiton like this.
    Nov 2010
    53
    59
    My car allready has HID's but I need to replace one of the headlight assembly's and the dealer wants $850.00 for a new one.
    caddyfat2 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS4 1SG w/ HUD-ACC
    Jul 2010
    TAMPA, FLORIDA
    462
    Quote Originally Posted by torogt View Post
    Good question. I would like to know also seeing I need to replace my driverside one too. I had both left and right headlights replaced 1.5 years ago at a cost of $1350 each by the Cadillac stealer.....oops I mean dealer and my leftside one went bad already.Does anyone know a definate answer to this mystery. if that will work then I will see about buying one too..
    Update: I did some research an found that it could be done but in the long run it's just easier to repair my leaking HID composite. Well Fall is now upon Florida so one sunny mild weekend I will devote to that project.I will drain and clean the composite as much as possible an reseal everywhere I see.
    6000k's Avatar
    6000k is offline Cadillac Owners Member
    Automobile(s): StS
    Oct 2010
    menifee CA
    27
    27
    Quote Originally Posted by hellamint View Post
    agreed dam bumper is a pain!
    but well worth it
    galaxy1000 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 STS V6 Lux
    Oct 2009
    Massachusetts
    53
    146
    I converted my non hid STS to HID's. Here is the link to an in depth post with pictures; http://www.cadillacforums.com/forums...nversions.html
    eatyoursandwich is offline Cadillac Owners Fanatic
    Automobile(s): 2007 STS N*
    Jan 2012
    Austin, TX
    31
    265
    Quote Originally Posted by galaxy1000 View Post
    That thread was helpful, but I have a set of OEM HID housings with OEM bulbs, ballasts, etc. I'm about to buy if I can get a definitive answer to one question.
    Common sense would lead me to believe that OEM halogen headlight harness is going to be different than the OEM HID headlight harness (e.g. extra pins). Can anyone confirm what the differences in the wiring harnesses are if any? Really really want to buy these, but want to make sure I don't have to hack up my harness to do it.
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    I recall a thread detailing some fine details of moving pins in the connector. Try the advanced search, limiting it to just this forum.
    Click "Search Single Content Type" and then scroll down to the drop-down and select our Cadillac STS Forum.
  12. Remove Advertisements
