Page 1 of 7 1234567 LastLast
Results 1 to 15 of 96
Thread: Intake Manifold Bolts
    mkmarsilio is offline Cadillac Owners Member
    Automobile(s): 2005 STS V8, Corsa exhaust, Volant CAI, Elite 20"x9.5R,8.5F
    Sep 2011
    Exclamation Intake Manifold Bolts
    Check to see if they are tight!!! 6 of 10 of mine were significantly loose. A 10 mm socket, wrench, and extension. Each will be needed to get around the fuel rail at different angles.
    Learned this by reading here
    sub613's Avatar
    sub613 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 STS 1SF N* RWD NAV F55
    Mar 2009
    NC for Now, Florida SOON
    704
    Re: Intake Manifold Bolts
    also at 100 in/lbs.
    Good Luck
    ddalder's Avatar
    ddalder is online now Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,852
    Which engine are you talking about? The LH2 bolts should be 89 lb in. or 10 N.m but I can't speak for the V6.
  5. #4
    Sep 2011
    Quote Originally Posted by ddalder View Post
    Thanks for the information! I thought I was finished - I only thought to use the elbow torque-o-meter. As far as motors go I am a V8 RWD type guy...getting rarer these days. I don't know if I have the adapters on hand to step my torque wrench down to the drive that fits my metrics? I thought my project was complete, but maybe to the store.
  6. #5
    ddalder's Avatar
    Aug 2008
    Canada
    2,852
    There have been several members on the forum speak of loose intake manifold bolts so I decided to check mine tonight and 6/10 were loose. Some as much as one full turn before I hit the 10 N.m torque.
    Since I was also doing a little work on my Bonneville, I decided to check it as well. I've got the LD8 engine in it (4.6L transverse mounted Northstar). It has about 111,000 km and I found every one of the 10 bolts was very loose. I initially made the assumption the torque spec was likely the same but when every one I checked seemed loose I checked the spec just to be sure. Nope, I wasn't overtightening! Hmmm, I wonder if this is a general Northstar problem or if it may be found on any GM engine with this style/type of manifold?
  7. #6
    Dj Brady is offline Cadillac Owners Member
    Automobile(s): 2005 N* STS4
    Aug 2011
    Wilmore, Ky
    42
    69
    just out of curiosity, are these headbolts "stretch" bolts, meaning, are they 'single use' bolts?
  8. #7
    ddalder's Avatar
    Aug 2008
    Canada
    2,852
    I believe you may be thinking of different bolts. I very much doubt these would be a stretch type bolt because the torque spec is so low. We're talking lb in., not lb ft. and to stretch, it would have to be an extremely soft alloy. Also, there is no mention in the FSM to use new bolts. Generally GM provides this when necessary.
  9. #8
    sub613's Avatar
    Mar 2009
    704
    Cool Re: Intake Manifold Bolts
    More on this: After reading about this on here, I headed down to my high school buddy's place about 150 Miles from home.
    I used 8 gal to get there, I tightened the bolts to 100 In Lbs, found ALL of them loose about 1 full turn, couldn't do the #1 or #2
    bolt in the sequence as there is a pressure switch type thing facing down toward the bolt, so used a open end, and did the best
    I could. Some of the indications: I noticed when pressing down lightly on the gas, it used to convert automatically from 5th (OD) to 4th gear.
    before the tightening, it didn't respond well, and I blamed my less than 26 MPG on rear tires, now it converts GREAT, and I only used
    6.5 Gals coming home, and the MPG avg, hit 26.6, which I have NOT seen in a long time. The transmission downshifting, usually has
    what they call a modulator, used to be (Vacuum controlled), this one also must be, as it works MUCH better now !
    Thanks to all who supplied the Correct info on this item, and helped me get this done.
    I wanted to use LOck tite on the bolts. You would have to pull the fuel racks to do this, I NEVER have done this, so I didn't do it.
    BTW, I ONLY have 45K miles on this, you would think they are NOT loose at this point, Murphy's law got me again !
  10. #9
    Aug 2011
    Wilmore, Ky
    42
    69
    Quote Originally Posted by Subsailor613 View Post
    That's a good bit of information and very inspirational! My average is under 20mpg as well. Is there a step by step to gain access to the intake bolts somewhere on here?
  11. #10
    1BadCadSTS's Avatar
    1BadCadSTS is offline Cadillac Owners Connoisseur
    Automobile(s): 05 STS4
    Nov 2010
    30
    4,224
    pull the beauty cover...
  12. #11
    Aug 2011
    Wilmore, Ky
    42
    69
    heh.. as soon as I hit enter, It dawned on me that the bolts would be readily available under the cover..
    hunting the sequence now.
  13. #12
    Aug 2011
    Wilmore, Ky
    42
    69
    I mean to address this post earlier and got sidetracked. You're correct. I was thinking of head bolts. Oops
  14. #13
    ddalder's Avatar
    Aug 2008
    Canada
    2,852
    I can't comment on a change in fuel economy just yet as I haven't driven enough since tightening the bolts to know. I can say that the first time I drive each day, or after the car has sat for several hours and cooled off, the car hesitates a little as I accelerate and I need to back off a little. Since tightening the intake manifold bolts, this appears to be resolved. I've also noticed a smoother, more powerful acceleration anytime I'm driving. Overall I'm happy with the results of a very simple maintenance procedure.
  15. #14
    ddalder's Avatar
    Aug 2008
    Canada
    2,852
    Quote Originally Posted by Dj Brady View Post
    This might be what you're looking for...
  16. #15
    Aug 2011
    Wilmore, Ky
    42
    69
    Close, but I park my car with the nose to the south.
    You got one of those?
  • You may not post replies
