Page 2 of 7 FirstFirst 1234567 LastLast
Results 16 to 30 of 96
Thread: Intake Manifold Bolts
  1. #16
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,852
    Re: Intake Manifold Bolts
    Quote Originally Posted by Dj Brady View Post
    Close, but I park my car with the nose to the south.
    You got one of those?
    This help?
  2. #17
    AnderbrA is offline Cadillac Owners Member
    Automobile(s): 2007 Cadillac STS V8
    May 2008
    Sioux Falls, SD
    95
    This whole thing had me curious...so over lunch I ran home and checked. To my astonishment, 9 of the 10 bolts were loose, with one almost ready to fall out. (pictured 2nd from firewall on drivers side) IMG00814-20110906-1501.jpg
    My STS is an 07 with shy of 98k. I couldn't believe these could come loose in less than 5 years.
    Amazingly this 5 minute fix immediately solved a number of issues.
    Rough idle and startup after car sat overnight.
    Hesitation in lower RPM. 700-1500
    Erratic shifting patterns, rough shift.
    I highly recommend everyone checks this out...should almost be sticky. Thus the beauty of an enthusiast forum.
  3. #18
    Dj Brady is offline Cadillac Owners Member
    Automobile(s): 2005 N* STS4
    Aug 2011
    Wilmore, Ky
    42
    69
    Quote Originally Posted by ddalder View Post
    This help?
    much better.. let me go grab my mirror now.
  4. #19
    AllWheelEric is offline Cadillac Owners Fanatic
    Automobile(s): 2005 STS4 1SG
    Jan 2006
    402
    Thanks for the advice, mkmarsilio, ddalder, and everyone else! I checked mine today and found they were very loose! I could tighten them with my fingers, if I had twisty little long skinny fingers. I have to go out tomorrow and find something like an articulating 3/8" extension, because I didn't have enough clearance to get my socket on most of the bolts. Harbor Freight is an hour away, but I'm sure they will have something, and I could use a motorcycle ride.
    Once again, very nice job to the forum members. Shame on Cadillac.
  5. #20
    Lifer's Avatar
    Lifer is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 Cadillac Eldorado ETC
    Apr 2007
    Coppell, TX
    905
    What do you know... 06 STS Northstar, 57,000 care-free miles. Checked the intake manifold bolts and had 10 out of ten loose to real loose. Tough to get to. Needed 10mm socket, flex adapter, and open end wrench. 10 minutes, and all better. Runs smoother now.
    How can Government (was the General once) Motors build them so sloppy? Perhaps this is one of reasons they had to use my money to bail them out.
  6. #21
    Lifer's Avatar
    Apr 2007
    Coppell, TX
    905
    Its only been a few days, but I have had a noticeable improvement in gas mileage. It was around 13.5 average for city - suburb driving, but now I am around 19.5. Next would be a road trip. My last on in August averaged 21 miles to the gallon.
  7. #22
    stevenriz is offline Cadillac Owners Enthusiast
    Automobile(s): 2008 STS4 V8 1SG Platinum Edition
    Apr 2009
    Central MA
    49
    544
    I did this as well last weekend to try and fix a stalling/misfire during off the line acceleration. The car does not stall now but does a funny acceleration like this... RUMM RUMM RUMM RUMM RUMM when going halfway on the pedal. Once I let off if smooths out. It is a little peppier and gas mileage has improved. I still need to have that checked. Other members suggested a clogged catalytic converter and/or bad/clogged fuel pump/filter...
  8. #23
    DitkaFan is offline Cadillac Owners Member
    Automobile(s): 08 STS-4 V6DI
    Feb 2011
    76
    I know quite a few people have verified this issue with the V8 N*s. But has anyone verified this is/isn't an issue with the V6s? Also does anyone have a diagram for the V6DI like was posted for the N*.
    Thanks.
  9. #24
    Aug 2011
    Wilmore, Ky
    42
    69
    Checked mine tonight. Most were finger loose, 3 were at least 3 threads out. Can't wait to see what it does for mileage. Can't say that "enriching" the combustion is going to do much for power though. leaner is always hotter..
  10. #25
    GREGB1954 is offline Cadillac Owners Member
    Automobile(s): '06 STS N* 1SG Pkg, blk/blk
    Nov 2010
    Indy
    56
    Just tightened the bolts on our '06 STS N* with 54k miles. All 10 were loose. Done in 10 min. Runs and shifts great now. This is a must do. I am going to check them every 10,000 mi or so.
    I could not get a socket on bolt #1 per diagram, so I used an open end 10mm wrench which is not ideal. So I will buy a crow foot wrench, or else remove the fuel rail. The other 9 bolts were easily reached with a 1/4" socket (10mm), with a std universal, then a 6" extension to my torque wrench.
    It might make sense to use an appropriate Loctite product. I wonder if there is a technical bulletin on this??
  11. #26
    nathanjax's Avatar
    nathanjax is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 esKONali
    May 2004
    Jax, FL
    36
    1,099
    Just tightened up mine. All 10 were loose. 2 or 3 i could tighten with my finger. 1 was about to fall out...
  12. #27
    chazglenn3's Avatar
    chazglenn3 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 White Diamond STS N* 1SF RWD ACC/HUD
    Sep 2004
    Tacoma, WA
    54
    1,959
    I'm planning to do this soon, and was just thinking about removing the fuel rail. I'll have to think about it. I did a quick check and found a couple loose.
  13. #28
    kschwed is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Cadillac STS 1SC
    Nov 2009
    California
    28
    383
    Does this apply to the V6 also?
  14. #29
    chazglenn3's Avatar
    Sep 2004
    Tacoma, WA
    54
    1,959
    This appears to be a NorthStar issue...
  15. #30
    sub613's Avatar
    sub613 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 STS 1SF N* RWD NAV F55
    Mar 2009
    NC for Now, Florida SOON
    704
    Cool Re: Intake Manifold Bolts
    I stand corrected: I got bum dope.
    for the V8 it's 89 in/lb ! Or
    7.2 Ft/Lb.
    Sorry !
  • You may not post replies
