Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Thread: How to fix or clear my headlights
    Nov 2010
    Manhattan, NYC (NY)
    31
    371
    Would like to know how to fix these headlights.
    FLASH OFF
    FLASH ON
    I PRESSED THE UNLOCK BUTTON ON MY REMOTE SO MY LIGHTS CAN TURN ON
    Jmac572 is offline Cadillac Owners Member
    Automobile(s): 2005 STS V6 RWD
    Oct 2003
    Massachusetts
    30
    52
    Re: How to fix or clear my headlights
    You are going to have to...
    1. Remove your front bumper
    2. Remove your headlights from your car
    3. Heat up the glue on each housing so you can remove the lens from the plastic gray housing
    4. Re-attach the plastic lens with a good glue/sealer after completely cleaning and drying the inside of the headlight housing and let it sit and dry all the way through
    5. Also, it is not a bad idea (since you may not know exactly what is letting moister in the headlights) to remove the two black access covers on the rear of the headlight housing so you can clean the seal and inspect the gasket... then make sure the gasket is seated correctly and the access covers are reattached securely
    Also, I can't really tell in the picture... But did you add aftermarket HIDs? If you did and you drilled into the housing to allow the wires access and did not properly seal/watertight the remaining space this will absolutely be a major contributor to your problem. That does appear to be a severe moisture issue and since it is identical on both headlights it makes me think this may be the real problem.
    BaTu is offline Cadillac Owners Enthusiast
    Automobile(s): '05 STS4
    May 2008
    668
    As long as they haven't been that way too long, and the corrosion hasn't started, you can remove them, dry them out, and reseal the clear lens to the body.
    I don't think it's actually necessary to remove the lenses, and take the chance of damaging them with too much heat, but rather by simply applying a new bead of sealant around the outer seam, it can be fixed.
    There a SO MANY posts on this with peoples experiences doing it,,,, you just have to Search on "condensation" or "moisture" in this forum to research it and see what others have done about it......
  5. #4
    Nov 2010
    Manhattan, NYC (NY)
    31
    371
    I am going to take it to my cousin's friend who installed HIDs on the car to see if it can be fixed.
    I really don't want to shed out $800-$1000 + for new headlights but I hope it can be fixed.
  6. #5
    Oct 2003
    Massachusetts
    30
    52
    Yes, I thought that was most likely the issue given the amount of condensation... Tell him to remove the headlights and completely dry out the housing (blasting a heat gun into one of the access covers on the rear of the headlight until dry should do it) then just put a liberal amount of some kind of a sealer to make sure no air can get in or out of any part of the hole he made in the housing to install the HID wiring, then you should be all set.
  7. #6
    galaxy1000 is offline Cadillac Owners Fanatic
    Automobile(s): 2009 STS V6 Lux
    Oct 2009
    Massachusetts
    53
    146
    After installing my HID's I had a similar issue, sealed everything twice and there was still a leak. Turned out to be a collapsed gasket.
  8. #7
    Nov 2010
    Manhattan, NYC (NY)
    31
    371
    I was told twice now to make a really tiny drill in each headlight unit
    But I dont know where to find something so small that'll drill thru so the air can come out
  9. #8
    May 2008
    668
    Quote Originally Posted by Frikiton View Post
    Really bad advice (you're talking to the wrong people....)
    Dry it out, seal ti up, and you'll have no more problems. Holes will only create new ones
  10. #9
    Nov 2010
    Manhattan, NYC (NY)
    31
    371
    Quote Originally Posted by BaTu View Post
    I figured it was def a bad advice.
  11. #10
    Jesda's Avatar
    Jesda is offline Super Moderator
    Automobile(s): 2002 Seville STS F55, 2006 Mazda Miata
    Sep 2003
    DETROIT
    35
    22,381
    The hole drilling generally works on 92-97 Seville tail lights because the moisture drains out the bottom. Those tail lights were also small, so there was less moisture per light to drain. That's likely where the idea came from, and I cant imaging it being effective on a large headlight like this.
    In addition, holes introduce the possibility of cracking.
  12. #11
    valjan1 is offline Cadillac Owners Member
    Automobile(s): 2005 sts4 1SG v8 perf pakge
    Dec 2009
    Montréal,Canada
    66
    44
    Do not drill holes
  13. #12
    Nov 2010
    Manhattan, NYC (NY)
    31
    371
    The guy that installed HIDs on my car also tried to get the condensation removed by blowing air pressure (it did work) for the first few days. Then passenger side headlight seem to gotten condensated again.
  14. #13
    LAC_STS is offline Cadillac Owners Enthusiast
    Automobile(s): STS
    Nov 2009
    786
    I have resealed both of my headlights. This is a very common issue.
    Take the headlights out, take the covers off, put a bead of clear silicone on there, and put the covers back on. You'll be good to go.
  15. #14
    Nov 2010
    Manhattan, NYC (NY)
    31
    371
    Quote Originally Posted by LAC_STS View Post
    This was done and only 1 side is good, the other side went back to a little condensated but not as much as before.
  16. #15
    kschwed is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Cadillac STS 1SC
    Nov 2009
    California
    28
    383
    Your problem may be on the back of the housing then. It is likely where the wires come in. Make sure that is also completely sealed up.
  • You may not post replies
