Fuse for Side Markers
Results 1 to 9 of 9
Cadillac STS Forum - 2005 through 2012 Discussion, Fuse for Side Markers in Past Cadillac Vehicle Discussion; Hello again all... I am troubleshooting lights on my 2006 STS, and my side markers are not working. To be ...
    Djwax337's Avatar
    Djwax337 is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac STS
    Sep 2010
    Louisiana
    34
    27
    Hello again all... I am troubleshooting lights on my 2006 STS, and my side markers are not working. To be more specific, the front and rear turn signals are working, but the bumper mounted marker & fender side markers are not working. I replaced the bulbs today thinking this was the problem to no avail. So i looked through the owners manual to find the corresponding fuse, once again to be baffled. Can anyone please direct me to the correct fuse for these, and its location (under hood/under rear seat). thanks again all for this hopefully trivial problem.
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,800
    Re: Fuse for Side Markers
    There are actually two fuses for the side marker lamps. One is "LT PARK" for the left side, and the other is "RT PARK" for the right. Each is 10A and both are located in the under hood fuse block. If all four lamps went out at once, I'd be more suspicious of the park lamp relay, also in the under hood fuse block.
    Charles Warren's Avatar
    Charles Warren is offline Cadillac Owners Fanatic
    Automobile(s): 2008 sts-v black raven 2004 cts black raven
    Nov 2011
    Atlanta, Georgia, United State
    88
    459
    My 08 is having the same issues. I looked in the fuse box and those are not blown and the taillights have no hyper flash. I need to bring out the test light to see if I'm getting any voltage. The rear side markers work but the fender reapeaters and front side markers are not working. The front drl/turns work as well. Seems like a easy fix once I trouble shoot it. Just lazy lol. Planes to cars smh lol
    ddalder's Avatar
    Aug 2008
    Canada
    2,800
    With only the fender mounted repeater lamps not working (in the signal lamp circuit), there will not be enough change in current draw to cause hyperflash. Have a look in the sockets for corrosion and check for poor contact with the bulb. I've had the same issue and that was my resolution.
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,497
    Feel free to swap them out with a set of these LEDs instead
    I'm using these ones:
    http://www.ebay.com/itm/351007067740
    Our car uses the same repeater lamps as the "VAUXHALL ASTRA MK4" uses, they have a bit more spacing behind them compared to ours though so the cabling can be a bit tight.
    Since you have to mess with yours anyways you might as well upgrade to LED
    ddalder's Avatar
    Aug 2008
    Canada
    2,800
    Not sure what's up with that vendor though. They will ship worldwide, but for some reason Canada (and some other countries listed) are ineligible. The item is in the United Kingdom, but apparently they won't even ship there???
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,497
    LOL that is pretty strange. I don't recall what seller I got mine from as it has been probably 2 years by now since I installed them.
    PontiacV8's Avatar
    PontiacV8 is offline Cadillac Owners Fanatic
    Automobile(s): 2015 Camaro 2SS, Sold: 2006 STS (EXP) 1997 Seville STS (EXP)
    Dec 2006
    Germany / Nordhorn
    423
    ...if needed...I've got a spare pair...
    ...btw...here the complete thread/theme:
    http://www.cadillacforums.com/forums...l#post10588730
    ...offtopic end
    ddalder's Avatar
    Aug 2008
    Canada
    2,800
    Thanks. I'm still contemplating because as I'm sure you know, I'm pretty particular about keeping everything GM (correct me if I'm wrong, but these appear aftermarket).
    I'm not worried about the sealed connection. I have the necessary parts to change the wedge style connector to a sealed connector that will mate directly with the harness. If I go ahead I'll PM you.
  12. Remove Advertisements
