Noise
Results 1 to 5 of 5
Cadillac STS Forum - 2005 through 2012 Discussion, Noise in Past Cadillac Vehicle Discussion; I have a 2008 sts4 6 cylinder and i am getting a whining noise at about 65mph and up and ...
    Miller Time is offline Cadillac Owners Member
    Automobile(s): 2008 sts4
    Mar 2011
    34
    14
    Noise
    I have a 2008 sts4 6 cylinder and i am getting a whining noise at about 65mph and up and it gets louder the faster i go it is a noise that last about a second and then goes away for a second and keeps cycling on and off the faster i go the worse faster and louder it is and if i put it in nuetral at say about 80mph it keeps on doing it but it does seem to stop if i am turnig the wheels to the left
    my car was just serviced for the timing chain stretching about 2 months ago and it has started doing this about 3 weeeks ago
    any help is appreciated
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Noise
    If it changes when the road curves left (enough for the weight to shift), it might be a left-side wheel bearing. Might it be coming from a wheel?
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,785
    Re: Noise
    Quote Originally Posted by EChas3 View Post
    Generally, if the road curves left and the type of noise you're referring to occurs, it would most often be the right side bearing. They are usually more noticeable when you load up the hub assembly. Turning left shifts the load right.
  5. #4
    Mar 2011
    34
    14
    Re: Noise
    i wrote it wrong when i turn to the right it goes away and the noise could possibly be coming from the front left side
    how could i ck the l bearing and any idea of cost the front wheel also has a slight bend in the front left wheeel
  6. #5
    EChas3's Avatar
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Noise
    Aren't you under warranty? Let them deal with it.
  7. Remove Advertisements
