Drivers Door Micro Switch Replacement "How-To" Part 2 - Page 3
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 31 to 45 of 57
Like Tree5Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Drivers Door Micro Switch Replacement "How-To" Part 2 in Past Cadillac Vehicle Discussion; Originally Posted by EChas3 Adding 'damping' to a speaker enclosure usually improves bass response. I watched a few online tutorials ...
  1. #31
    FranchiseSTS is offline Cadillac Owners Member
    Automobile(s): 2008 STS AWD V8
    Apr 2011
    35
    16
    Re: Drivers Door Micro Switch Replacement "How-To" Part 2
    Quote Originally Posted by EChas3 View Post
    I watched a few online tutorials about installing dynamat and products like it. They showed putting the dynamat on the outside of the door, where the plastic rain shield is. However, I was watching a show on HDNET where they put the dynamat on the inside of the door, on the body itself (does that make sense). Is this a good idea, it seems like it is, and relatively easy to install there. They showed how it made the door sound more solid, when you taped on it, which made sense. I have a few sheets left over. This should improve the bass response more right?
  2. #32
    mike sts is offline Cadillac Owners Fanatic
    Jul 2004
    158
    I know Im responding to an old thread but does anyone know If the
    micro switch can be purchased separately from the housing
  3. #33
    B1n2fra's Avatar
    B1n2fra is offline Cadillac Owners Enthusiast
    Automobile(s): 2007 1SG STS v8 awd
    Nov 2011
    Chicago
    36
    502
    Quote Originally Posted by mike sts View Post
    Nope. Unless you go to a junk yard
  5. #34
    Ludacrisvp's Avatar
    Ludacrisvp is offline Cadillac Owners Connoisseur
    Feb 2009
    St Michael, MN
    30
    4,524
    So how hard would it be to "convert" the rear doors to electric handles? Hmmm.
  6. #35
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,812
    Quote Originally Posted by Ludacrisvp View Post
    There is definitely some work involved, in fact I really don't think it is possible.
    Each door handle has two switches, one that connects directly to the RCDLR (separate inputs left and right side) and on that connects to the respective door module. In addition, each door has an antenna that connects to a separate input on the RCDLR. I can't see any way to add these components in such a way that the car will be able to recognize and properly respond to a handle pull. Then there is the process of converting to an electric latch in the rear doors.
    I've thought about this myself but I came to a lot of dead ends...
  7. #36
    Jul 2004
    158
    one more question when you lubricate the parts with lithium grease before re assembly do you put any around the lock when doing the driver side? I think locks need a special powder type lube but forgot
  8. #37
    B1n2fra's Avatar
    Nov 2011
    Chicago
    36
    502
    Quote Originally Posted by Neutrocuted View Post
    The drivers door is 19120306, passenger door is 19120307.
    Are part numbers 25979141 and 25979140 also compatible with the sts also. I seen them listed comapatible for an sts and cts.
  9. #38
    Neutrocuted's Avatar
    Neutrocuted is offline Cadillac Owners Fanatic
    May 2010
    457
    Sorry... can't help with compatibility question.
  10. #39
    KGFellers is offline Cadillac Owners Member
    Automobile(s): 2006 STS 4 (AWD)
    Nov 2012
    13
    All your info has been great. I have an additional question however......does the outside door handle have a mechanical connection tothe inside unlatching mechanism? I found some frayed wires leading to the lock mechanism and taped them but the door will still not
    open from the outside.....I still have to use my key to get in. All other doors are ok. Fobs are ok. Thanks again for the help.
  11. #40
    dannyquest is offline Cadillac Owners Fanatic
    Mar 2012
    columbus ohio
    382
    Just the inside door handle has a mechanical connection rod going to it. Danny
  12. #41
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,524
    Correct.
    For the front doors no mechanical connection from outside.
    (Rear are different)
  13. #42
    B1n2fra's Avatar
    Nov 2011
    Chicago
    36
    502
    Correct.
    Except the key hole on the drivers side
  14. #43
    Ludacrisvp's Avatar
    Feb 2009
    St Michael, MN
    30
    4,524
    Quote Originally Posted by B1n2fra View Post
    Oops ... There is that too.
  15. #44
    B1n2fra's Avatar
    Nov 2011
    Chicago
    36
    502
    Lol.
  16. #45
    wormser is offline Cadillac Owners Member
    Automobile(s): 2008 STS V8
    Jan 2014
    STL, MO
    31
    20
    I have found this thread to be extremely helpful. After some investigating and tearing apart of the door, I think my problem is the antenna. Any thoughts on how to replace/fix this?
    Thanks.
  17. Remove Advertisements
