Results 1 to 5 of 5
Thread: Replace belt Tensioner pulley on CTS 2003
    gary_jabo is offline Cadillac Owners Member
    Automobile(s): CTS 2003
    Mar 2011
    7
    Hi;
    I just bought a used 2003 CTS with the 3.2L engine. I thas 112,000 miles. The belt tensioner pulley is making noise. Is it easier to change just the pulley and bearing or should I go for changing the whole tensioner assembly.
    Are there any tricks on removing the belt? It looks easy but this is my first CTS. What is the best way to relieve the tension on the belt.
    Any advice is appreciated. I'm new to this forum but not new to Cadillac. I previously owned a 1986 DeVille with the 4.1L V8 and a 1983 Cimarron. Both were interesting cars with a lot of memories.
    Thanks for reading.
    SID in Atlanta.
    EChas3's Avatar
    EChas3 is offline Cadillac Owners Master
    Automobile(s): 2006 STS4 V8 1SG & 2007 STS V8 1SE
    Jun 2008
    Cedarburg, WI
    59
    8,178
    Re: Replace belt Tensioner pulley on CTS 2003
    Try the CTS forum. You'll likely get more applicable responses because none of our cars have the 3.2.
    jrrsmith18 is offline Cadillac Owners Member
    Automobile(s): 01 catera, 08 sts
    Dec 2008
    Ohio
    28
    73
    nope nothing special to it, changed it on my catera (pretty much same engine), just make sure you put the belt back on in the grooves, routed right and you should be good
  5. #4
    8323matt's Avatar
    8323matt is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Cadillac STS
    Nov 2010
    Fargo, ND
    182
    Its cheaper to change just the pulley. The dealer said it was only 50 cents cheaper than the whole tensioner which was $72. So I bought mine of Rockauto.com for 12 dollars
  6. #5
    Mar 2011
    7
    Please accept my apologies. I posted this message to the wrong forum. But thanks for the advice.
    Anyway, I did change the belt tensioner pulley. It was $17 and the step that took the longest was buying the new part. My total labor was about 15 minutes once I had the parts.
    Regards
    SID
  • You may not post replies
