Oil Life Indicator in the STS - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Like Tree1Likes
Cadillac STS Forum - 2005 through 2012 Discussion, Oil Life Indicator in the STS in Past Cadillac Vehicle Discussion; Originally Posted by RippyPartsDept yeah, in the owner's manual it will tell you what to do if you accidentally reset ...
  1. #16
    ddalder's Avatar
    ddalder is offline Cadillac Owners Connoisseur
    Automobile(s): 08 STS-4 N* 1SG, 08 DTS Luxury II, 04 Bonneville GXP N*
    Aug 2008
    Canada
    2,785
    Re: Oil Life Indicator in the STS
    yeah, in the owner's manual it will tell you what to do if you accidentally reset the monitor
    i think it says get it done right away if you're over 3000 miles on the oil change or get it done at 3000 miles since the last change
    the rpm and temp are the two variables... i mentioned the 'application' first since it is the major factor but it isn't a variable unless you're talking about the OLM system in general - when you're talking about a specific car the rpm and temp are the only variables that go into the algorithm
    I was referring to the system in general because in the case of our fleet vehicles we have a variety of different GM products that have an OLM. In any event, I knew where you were going with that. As for the accidental reset, our practice is to reasign a new interval of 5,000km since the last change. Our vehicles are driven hard so to sneak one in earlier than usual won't ever hurt
  2. #17
    sub613's Avatar
    sub613 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 STS 1SF N* RWD NAV F55
    Mar 2009
    NC for Now, Florida SOON
    704
    CoolRe: Oil Life Indicator in the STS
    Thanks, RippyParts, well said !
  3. #18
    KRSTS Guest
    10287 bulletin.pdf Acrobat PDF (77.17KB) 10287
    CUSTOMER SATISFACTION PROGRAM
    SUBJECT: Premature Timing Chain Wear – Reprogram Engine Control Module
    MODELS: 2009 Buick Enclave
    2007-2009 Cadillac CTS, SRX, STS
    2009 Chevrolet Traverse
    2007 GMC Acadia
    2009 GMC Acadia
    2007 Saturn OUTLOOK
    2009 Saturn OUTLOOK
    Equipped with HFV6 Engine
    Due to the availability of the required calibration, this program is being administered in
    phases. This first phase will include the Cadillac vehicles only. You will receive a dealer
    message when the calibration and VINs are being released for the remainder of the
    vehicles.
    THIS PROGRAM IS IN EFFECT UNTIL FEBRUARY 28, 2013.
    CONDITION
    On certain 2007 model year GMC Acadia; Saturn OUTLOOK; 2007-2009 model year Cadillac
    CTS, SRX, STS; 2009 model year Buick Enclave; Chevrolet Traverse; GMC Acadia; and Saturn
    OUTLOOK vehicles equipped with a HFV6 engine, under certain driving conditions, and with
    extended oil change intervals, the timing chain could wear prematurely and cause the
    illumination of the Service Engine Soon light.
    CORRECTION
    Dealers are to reprogram the engine control module, including the engine oil life monitor.
    which in most cases will recommend more frequent oil changes.
    So much for the GM OLM algorthm. They don't seemed to be too concerned about the premature timing chain wear, just that the Service Engine Soon light comes on. They are probably doing the reprogram so that it will extend the life of the chain a couple more years, so that you are out of the warranty period when it does finally crap out. I'm sure glad now that I have changed my oil every 5000 - 6000 miles anyway. Hopefully my ZDDP didn't get too low.
  4. #19
    ddalder's Avatar
    Aug 2008
    Canada
    2,785
    I don't know that it's fair to say the OLM is at fault here. In the big picture, this seems to be a fairly limited problem. Perhaps with the affected units a different vendor manufactured some of the internal engine parts. Perhaps some of the material was not to GM's spec. Who knows? Increasing oil changes to compensate for what should not have occurred may be their best (corporate) was of dealing with it. I wouldn't recommend jumping to conclusions from a service bulletin as to the true scope about what brought this action. The OLM has been around for at least 11 years that I'm aware of (perhaps even longer) and I'm not aware that wide-spread problems have occurred as a result of its use.
  5. #20
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    OLM was developed in the 80's and introduced in the 90's
    if you just glossed over that long blockquote of text that i posted go back and read it in full
  6. #21
    ddalder's Avatar
    Aug 2008
    Canada
    2,785
    Went back read it again, what specifically are you getting at?
  7. #22
    KRSTS Guest
    Quote Originally Posted by ddalder View Post
    Perhaps I was too hasty in judging the OLM. I am a cynic by nature so here's my take:
    I think that only certain VINs within certain MYs are affected due to installation of faulty timing chains. In turn , it seems that optimal lubrication via more frequent oil changes, is necessary to keep the engines that were outfitted with the inferior chains from developing stretched chains. I guess that this is really a chain issue rather than an engine design issue or a bad OLM and that it is easier and less costly for GM to recalibrate the OLM and ECM than to replace the bad chains. This is a band aid fix to help GM avoid covering alot of $3000+ chain repair jobs i.e. Toyota floor mats?
  8. #23
    ddalder's Avatar
    Aug 2008
    Canada
    2,785
    Quote Originally Posted by KRSTS View Post
    I think you see what I'm getting at. If a part or parts were made a marginally "heavier" to compensate for a lesser grade material, there may be more surface contact points resulting in a more rapid depletion of ZDP. The same may apply if a part wasn't machined to spec. I'm definitely not a metallurgist but this seems to make sense. Just a theory.
  9. #24
    Sep 2007
    Wilmington, NC
    13,986
    i wasn't really talking to you since you read it already...
    i was just making sure that anyone who came upon this thread and pulled a 'tl; dr' would stop and go back and take the time to fully understand the OLM system
  10. #25
    ddalder's Avatar
    Aug 2008
    Canada
    2,785
    Ah, sorry. I do tend to skim sometimes but still wondered if I was missing something. Wouldn't be the first time LOL
  11. Remove Advertisements
